sample_multi_transcode H265->h264 error
xia__shane
Hi,everyone:
              Recently, I use  sample_multi_transcode to transcode&&pull   a rtsp stream encoded HEVC to a streaming media server encoded h264.
              I add  ffmpeg to the sample_multi_transcode code for pulling stream.The program works fine.But when i play the dst url,error happend. Either I use vlc or ffplay ,the screen is black. The ffplay report like this:
                             SPS unavailable in decode_picture_timing
non-existing PPS 0 referenced
no frame!
No problem happened when i save the rtsp stream into local file. So i guess something wrong in my net part program.
I search in google,only give answer:no pps
I am a fresh.Could anyone give me some specific suggestions? Did anyone meet the same problem?
Yours sincerely,
shane
xia__shane
ps:I have already installed HEVC Plugin.
xia__shane
My Dst url is like this:
rtsp://IP:port/RTStream/*.sdp
