Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
sample_multi_transcode.exe for composition
iroeville
I'm having problems trying to get the syntax right for getting the sample_multi_transcode.exe sample to do composition - i.e.using the -vpp_ command line options in the par file. Everything I've tried so far seems to give syntax error messages.
Do you have a working example par file for sample_multi_transcode.exe that successfully composes two h264 input files to a single h264 output file (or similar) ?
Anna_B_Intel
Hi Iroeville,
Try to write the following strings in .par file:
-i::h264 input1.264 -vpp_comp_dst_y 0 -n 300 -vpp_comp_dst_h 135 -vpp_comp_dst_x 0 -join  -vpp_comp_dst_w 480 -hw -f 30 -o::sink
-i::h264 input2.264 -vpp_comp_dst_y 0 -n 300 -vpp_comp_dst_h 135 -vpp_comp_dst_x 480 -join  -vpp_comp_dst_w 480 -hw -f 30 -o::sink
-i::source -h 1080 -b 8700 -w 1920 -join  -async 1 -hw -n 300 -fe 30 -vpp_comp 2 -l 1 -o::h264 output.h264
Best wishes,
Anna
Anna_B_Intel
Hi Iroeville,
Best wishes,
Anna
iroeville
Thanks Anna. I tried this with the pre-built sample_multi_transcode.exe and a couple of 1920x1088 sized h264 files that are 234 frames in length, so slightly changed values like this:
-i::h264 f1.h264 -vpp_comp_dst_y 0 -n 234 -vpp_comp_dst_h 135 -vpp_comp_dst_x 0 -join  -vpp_comp_dst_w 480 -hw -f 30 -o::sink
-i::h264 f1a.h264 -vpp_comp_dst_y 0 -n 234 -vpp_comp_dst_h 135 -vpp_comp_dst_x 480 -join  -vpp_comp_dst_w 480 -hw -f 30 -o::sink
-i::source -h 1088 -b 8700 -w 1920 -join  -async 1 -hw -n 234 -fe 30 -vpp_comp 2 -l 1 -o::h264 output.h264
It seems to process OK with this transcript:
D:\TEMP>"D:\Intel Media SDK Samples 2016 6.0.0.142\_bin\win32\sample_multi_trans
code.exe" -par multi_trans_par_intel.txt
Multi Transcoding Sample Version 6.0.0.142
Par file is: multi_trans_par_intel.txt
MFX HARDWARE Session 0 API ver 1.11 parameters:
Input  video: AVC
Output video: To child session
MFX dll: C:\Program Files\Intel\Media SDK\libmfxhw32.dll
MFX HARDWARE Session 1 API ver 1.11 parameters:
Input  video: AVC
Pipeline surfaces number: 8
Pipeline surfaces number: 2
MFX HARDWARE Session 2 API ver 1.11 parameters:
Input  video: From parent session
Output video: AVC
Pipeline surfaces number: 15
Session 0 was joined with other sessions
Session 1 was joined with other sessions
Session 2 was joined with other sessions
Transcoding started
Transcoding finished
Common transcoding time is  2.07 sec
MFX session 0 transcoding PASSED:
Processing time: 1.95 sec
Number of processed frames: 234
MFX session 1 transcoding PASSED:
MFX session 2 transcoding PASSED:
Processing time: 2.07 sec
The test PASSED
The output.h264 file seems to be identified OK in MediaInfo - but VLC will not play it although it will play the input h264 files.
Any idea what is wrong?
Anna_B_Intel
According to command line output transcoding is correct. I'm not clear does VNC work with raw video. Usually players work with video in containers. I reproduced the scenario and Windows Media Player plays the output fine. Also sample_decode can render it well.
Best wishes,
Anna
iroeville
Thanks Anna. I can confirm that the output h264 file does play OK in Windows Media Player. It looks like this might be an issue with VLC.
