Media (Intel® oneAPI Video Processing Library, Intel Media SDK)
Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
2970 Discussions
sample_multi_transcode failed on windows (MFX_ERR_MEMORY_ALLOC)
makefriend8
MSDK version: 20.3.0
OS: Microsoft Windows [ 10.0.19041.685]
Graphics Card: Intel(R) UHD Graphics 630    27.20.100.9030
run
sample_multi_transcode.exe -par n16_noface_test_1080p.par
Multi Transcoding Sample Version 20.3.0
Par file is: n16_noface_test_1080p.par
External allocator will be used as some cmd line paremeters request it.
Some inter-sessions do not use opaque memory (possibly because of -o::raw).
Opaque memory in all inter-sessions is disabled.
Session 0:
MFX HARDWARE Session 0 API ver 1.34 parameters:
Input video: AVC
Output video: To child session
MFX dll: C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_f48be35b3d221b44\libmfxhw64.dll
Session 1:
MFX HARDWARE Session 1 API ver 1.34 parameters:
Input video: AVC
Session 2:
MFX HARDWARE Session 2 API ver 1.34 parameters:
Input video: AVC
Session 3:
MFX HARDWARE Session 3 API ver 1.34 parameters:
Input video: AVC
Session 4:
MFX HARDWARE Session 4 API ver 1.34 parameters:
Input video: AVC
Session 5:
MFX HARDWARE Session 5 API ver 1.34 parameters:
Input video: AVC
Session 6:
MFX HARDWARE Session 6 API ver 1.34 parameters:
Input video: AVC
Session 7:
MFX HARDWARE Session 7 API ver 1.34 parameters:
Input video: AVC
Session 8:
MFX HARDWARE Session 8 API ver 1.34 parameters:
Input video: AVC
Session 9:
MFX HARDWARE Session 9 API ver 1.34 parameters:
Input video: AVC
Session 10:
MFX HARDWARE Session 10 API ver 1.34 parameters:
Input video: AVC
Session 11:
MFX HARDWARE Session 11 API ver 1.34 parameters:
Input video: AVC
Session 12:
MFX HARDWARE Session 12 API ver 1.34 parameters:
Input video: AVC
Session 13:
MFX HARDWARE Session 13 API ver 1.34 parameters:
Input video: AVC
Session 14:
MFX HARDWARE Session 14 API ver 1.34 parameters:
Input video: AVC
Session 15:
MFX HARDWARE Session 15 API ver 1.34 parameters:
Input video: AVC
Session 16:
[ERROR], sts=MFX_ERR_MEMORY_ALLOC(-4), TranscodingSample::CTranscodingPipeline::AllocFrames, CalculateNumberOfReqFrames failed at d:\code\mywork\ffmpeg\mediasdk-intel-mediasdk-20.3.0\samples\sample_multi_transcode\src\pipeline_transcode.cpp:3270
[ERROR], sts=MFX_ERR_MEMORY_ALLOC(-4), TranscodingSample::CTranscodingPipeline::Init, AllocFrames failed at d:\code\mywork\ffmpeg\mediasdk-intel-mediasdk-20.3.0\samples\sample_multi_transcode\src\pipeline_transcode.cpp:3848
[ERROR], sts=MFX_ERR_MEMORY_ALLOC(-4), TranscodingSample::Launcher::Init, pThreadPipeline->pPipeline->Init failed at d:\code\mywork\ffmpeg\mediasdk-intel-mediasdk-20.3.0\samples\sample_multi_transcode\src\sample_multi_transcode.cpp:448
[ERROR], sts=MFX_ERR_MEMORY_ALLOC(-4), wmain, transcode.Init failed at d:\code\mywork\ffmpeg\mediasdk-intel-mediasdk-20.3.0\samples\sample_multi_transcode\src\sample_multi_transcode.cpp:1158
content of n16_noface_test_1080p.par
-i::h264 ./classroom.h264  -join -hw  -async 4 -dec_postproc   -o::sink -vpp_comp_dst_x 0 -vpp_comp_dst_y 0 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -fps 30
-i::h264 ./2.h264 -join -hw  -async 4 -dec_postproc   -o::sink -vpp_comp_dst_x 480 -vpp_comp_dst_y 0 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -fps 30
-i::h264 ./3.h264 -join -hw  -async 4 -dec_postproc   -o::sink -vpp_comp_dst_x 960 -vpp_comp_dst_y 0 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -fps 30
-i::h264 ./4.h264 -join -hw  -async 4 -dec_postproc   -o::sink -vpp_comp_dst_x 1440 -vpp_comp_dst_y 0 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -fps 30
-i::h264 ./4.h264 -join -hw  -async 4 -dec_postproc   -o::sink -vpp_comp_dst_x 0 -vpp_comp_dst_y 270 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270  -fps 30
-i::h264 ./classroom.h264 -join -hw  -async 4 -dec_postproc   -o::sink -vpp_comp_dst_x 480 -vpp_comp_dst_y 270 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -fps 30
-i::h264 ./2.h264 -join -hw  -async 4 -dec_postproc   -o::sink -vpp_comp_dst_x 960 -vpp_comp_dst_y 270 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270  -fps 30
-i::h264 ./3.h264 -join -hw  -async 4 -dec_postproc   -o::sink -vpp_comp_dst_x 1440 -vpp_comp_dst_y 270 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270  -fps 30
-i::h264 ./2.h264 -join -hw  -async 4 -dec_postproc   -o::sink -vpp_comp_dst_x 0 -vpp_comp_dst_y 540 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -fps 30
-i::h264 ./3.h264 -join -hw  -async 4 -dec_postproc   -o::sink -vpp_comp_dst_x 480 -vpp_comp_dst_y 540 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -fps 30
-i::h264 ./4.h264 -join -hw  -async 4 -dec_postproc   -o::sink -vpp_comp_dst_x 960 -vpp_comp_dst_y 540 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -fps 30
-i::h264 ./classroom.h264 -join -hw  -async 4 -dec_postproc   -o::sink -vpp_comp_dst_x 1440 -vpp_comp_dst_y 540 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -fps 30
-i::h264 ./3.h264 -join -hw  -async 4 -dec_postproc   -o::sink -vpp_comp_dst_x 0 -vpp_comp_dst_y 810 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270  -fps 30
-i::h264 ./4.h264 -join -hw  -async 4 -dec_postproc   -o::sink -vpp_comp_dst_x 480 -vpp_comp_dst_y 810 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -fps 30
-i::h264 ./classroom.h264 -join -hw  -async 4 -dec_postproc   -o::sink -vpp_comp_dst_x 960 -vpp_comp_dst_y 810 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -fps 30
-i::h264 ./2.h264 -join -hw  -async 4 -dec_postproc   -o::sink -vpp_comp_dst_x 1440 -vpp_comp_dst_y 810 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270  -fps 30
-vpp_comp 16 -w 1920 -h 1080 -async 4 -threads 2 -join -hw  -threads 3 -i::source -ext_allocator -ec::nv12 -o::h264 comp_out_1080p_2.h264 -b 8000
Mark_L_Intel1
Hi Mars,
I had confirmed the video composition is limited to 8 per tile, it is defined in following place:
https://github.com/projectceladon/MediaSDK/blob/master/_studio/mfx_lib/vpp/include/mfx_vpp_defs.h#L4...
Can you change your original par file to see if it works by limited to 8?
Mark
RaeesaM_Intel
We are trying to figure out your issue internally. We will get back to you on the updates.
Raeesa
RaeesaM_Intel
Could you please confirm that the input files and par file are in the same directory.
Raeesa
makefriend8
RaeesaM_Intel
We are forwarding this case to subject matter experts for much faster and adequate response.
Thank you
Raeesa
Mark_L_Intel1
Hi Mars,
Sorry for the late response.
I can reproduce it and I have reported to dev team for investigation, I will keep you updated.
Mark
Mark_L_Intel1
Hi Mars,
I got some progress, it seems the composition function has some limitation:
  • Some combination of different FPS videos doesn't work.
  • Some combination of different resolution videos doesn't work
  • The number of input videos should less than 8.
I will confirm this, but I think this should be expected. The sample_multi_transcode is a test tool to validate the SDK, it doesn't check all use cases.
I used these sample videos to do the test(I guess these are similar as yours), I used the following command to extract the raw input:
>ffmpeg -i <input.mp4> -vcodec copy -an -bsf h264_mp4toannexb <output.h264>
The following par file works for me:
-i::h264 ./classroom.h264 -hw -async 4 -dec_postproc -vpp_comp_dst_x 0 -vpp_comp_dst_y 0 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -join -o::sink
-i::h264 ./bottle-detection.h264 -hw -async 4 -dec_postproc -vpp_comp_dst_x 480 -vpp_comp_dst_y 0  -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -join -o::sink
-i::h264 ./car-detection.h264 -hw -async 4 -dec_postproc -vpp_comp_dst_x 0 -vpp_comp_dst_y 270  -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -join -o::sink
-i::h264 ./bolt-detection.h264 -hw -async 4 -dec_postproc -vpp_comp_dst_x 480 -vpp_comp_dst_y 270  -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -join -o::sink
-vpp_comp 4 -fps 10 -ext_allocator -ec::nv12 -o::h264 comp_out_1080p_2.h264 -b 8000 -join -i::source
but if I replace "bolt-detection.h264" with "people-detection.h264", the above par file doesn't work.
The following par file also work when I used the same input:
-i::h264 ./classroom.h264 -hw -async 4 -dec_postproc -vpp_comp_dst_x 480 -vpp_comp_dst_y 0  -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -join -o::sink
-i::h264 ./classroom.h264 -hw -async 4 -dec_postproc -vpp_comp_dst_x 960 -vpp_comp_dst_y 0  -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -join -o::sink
-i::h264 ./classroom.h264 -hw -async 4 -dec_postproc -vpp_comp_dst_x 1440 -vpp_comp_dst_y 0  -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -join -o::sink
-i::h264 ./classroom.h264 -hw -async 4 -dec_postproc -vpp_comp_dst_x 0 -vpp_comp_dst_y 270 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -join -o::sink
-i::h264 ./classroom.h264 -hw -async 4 -dec_postproc -vpp_comp_dst_x 480 -vpp_comp_dst_y 270 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -join -o::sink
-i::h264 ./classroom.h264 -hw -async 4 -dec_postproc -vpp_comp_dst_x 960 -vpp_comp_dst_y 270 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -join -o::sink
-i::h264 ./classroom.h264 -hw -async 4 -dec_postproc -vpp_comp_dst_x 1440 -vpp_comp_dst_y 270 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -join -o::sink
-vpp_comp 8 -fps 10 -ext_allocator -ec::nv12 -o::h264 comp_out_1080p_2.h264 -b 8000 -join -i::source
and,
-i::h264 ./classroom.h264 -hw -async 4 -dec_postproc -vpp_comp_dst_x 0 -vpp_comp_dst_y 540 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -join -o::sink
-i::h264 ./classroom.h264 -hw -async 4 -dec_postproc -vpp_comp_dst_x 480 -vpp_comp_dst_y 540 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -join -o::sink
But increase the "-vpp_comp" to 9 make it failed.
Mark
Mark_L_Intel1
Hi Mars,
Mark
dsncml
I set the quantity of tiles to 2 and assign tile_id for each channels of composition (to make sure the limit is not exceeded), but it doesn't work.
-i::h264 ./classroom.h264 -hw -async 4 -dec_postproc -vpp_comp_dst_x 0 -vpp_comp_dst_y 0 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -vpp_comp_tile_id 0 -join -o::sink
-i::h264 ./classroom.h264 -hw -async 4 -dec_postproc -vpp_comp_dst_x 480 -vpp_comp_dst_y 0  -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -vpp_comp_tile_id 0 -join -o::sink
-i::h264 ./classroom.h264 -hw -async 4 -dec_postproc -vpp_comp_dst_x 960 -vpp_comp_dst_y 0  -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -vpp_comp_tile_id 0 -join -o::sink
-i::h264 ./classroom.h264 -hw -async 4 -dec_postproc -vpp_comp_dst_x 0 -vpp_comp_dst_y 270  -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -vpp_comp_tile_id 0 -join -o::sink
-i::h264 ./classroom.h264 -hw -async 4 -dec_postproc -vpp_comp_dst_x 480 -vpp_comp_dst_y 270 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -vpp_comp_tile_id 0 -join -o::sink
-i::h264 ./classroom.h264 -hw -async 4 -dec_postproc -vpp_comp_dst_x 960 -vpp_comp_dst_y 270 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -vpp_comp_tile_id 0 -join -o::sink
-i::h264 ./classroom.h264 -hw -async 4 -dec_postproc -vpp_comp_dst_x 0 -vpp_comp_dst_y 540 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -vpp_comp_tile_id 0 -join -o::sink
-i::h264 ./classroom.h264 -hw -async 4 -dec_postproc -vpp_comp_dst_x 480 -vpp_comp_dst_y 540 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -vpp_comp_tile_id 0 -join -o::sink
-i::h264 ./classroom.h264 -hw -async 4 -dec_postproc -vpp_comp_dst_x 0 -vpp_comp_dst_y 810 -vpp_comp_dst_w 480 -vpp_comp_dst_h 270 -vpp_comp_tile_id 1 -join -o::sink
-vpp_comp 9 -fps 10 -ext_allocator -ec::nv12 -o::h264 comp_out_1080p_2.h264 -b 8000 -vpp_comp_num_tiles 2 -join -i::source
Mark_L_Intel1
Hi Mars,
Sorry for the late response, I somehow missed your post.
Did you got the same error message as before?
Check your command, I noticed "-comp 9" in the last line, since the library only allows 8 input streams, this should be 8.
Could you change this and try again? Or try my tar file and see if it be successful.
Mark
