sample_multi_transcode failure
Zezynski__Ben
I run the folllowing sample:
~/work/MediaSDK/build/__bin/release$ ./sample_multi_transcode -i::h264 ~/work/MediaSDK/tests/content/test_stream.264 -o::h264 out.264
I get the following error:
Multi Transcoding Sample Version 8.4.27.
libva info: VA-API version 1.6.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so
libva info: Found init function __vaDriverInit_1_6
libva info: va_openDriver() returns 0
Session 0:
[ERROR], sts=MFX_ERR_MORE_DATA(-10), Init, pThreadPipeline->pPipeline->Init failed at /home/baseline/work/MediaSDK/samples/sample_multi_transcode/src/sample_multi_transcode.cpp:442
[ERROR], sts=MFX_ERR_MORE_DATA(-10), main, transcode.Init failed at /home/baseline/work/MediaSDK/samples/sample_multi_transcode/src/sample_multi_transcode.cpp:1169
Any help?
Dmitry_E_Intel
Please duplicate the issue here: https://github.com/Intel-Media-SDK/MediaSDK/issues
