Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
sample_vpp_drm convert yv12 to nv12
Yabo_W_
Hi all:
I had a test of sample_vpp_drm, which is Intel media SDK 1.10's sample. My output pixel format is nv12, and I think the order of U and V  is reversed.
first step: create a yv12 rawvideo with ffmpeg:
./ffmpeg -i /mnt/upload/MPEGTS/Earth_TR2_1080.ts -frames 500  -vcodec rawvideo -pix_fmt yuv420p -s 1920x1080 -an ./input_yv12.yuv
second step:
convert input_yv12.yuv from yv12 to nv12:
sudo ./_bin/x64/sample_vpp_drm -lib hw -sw 1920 -sh 1080 -scc yv12 -spic 0 -dcc nv12 -dw 1920 -dh 1080 -i ./input_yv12.yuv -o ./output.yuv
finally:
play output.yuv with ffplay:
ffplay -pix_fmt nv12 output.yuv
the output's color is incorrect
but when I use nv21 pixer format, the output's color is correct:
ffplay -pix_fmt nv21 output.yuv
the input_yv12.yuv is like this:
ffplay -pix_fmt yuv420p -s 1920x1080 input_yv12.yuv
Surbhi_M_Intel
Hi Yabo,
Can you please check again if the input this is generated is YV12 input. They YV12 format is quite same as YUV420p but the U and V data is reversed. If you don't have tool to check that, then you can use YUV tool kit available online to check.
I think because of assuming the input to be YV12, the colors of output is reversed. Please let us know your findings
-Surbhi
Yabo_W_
Hi SURBHI
This is my fault.They YV12 format is quite same as YUV420p but the U and V data is reversed. Below is the explain of YUV420P and YV12
http://en.wikipedia.org/wiki/YUV#Y.27UV420p_.28and_Y.27V12_or_YV12.29_to_RGB888_conversion
Best regards!
Thanks!
