sample_vpp -> MFX_ERR_INVALID_VIDEO_PARAM
Dmitry_Gurulev
Hi All, I'm trying to play with MSDK 2013. I've built sample_vpp video processing sample and try to execute it with following command line <-i "vpp\test_720x576.rgb24" -o "vpp\result.nv12" -lib hw -n 10 -sw 720 -sh 576 -scc rgb3 -dw 320 -dh 240 -dcc nv12> but I have status code MFX_ERR_INVALID_VIDEO_PARAM at line 436 of sts = pProcessor->pmfxVPP->QueryIOSurf(pParams, request); I've tried to use software (-lib sw), different CC combination (yuy2,yv12,rgb3,rgb4) including In==Out, but I have only the same error. Could you help me with this error? System info and Media SDK tracer logs are attached in vpp.zip archive.
Dmitry_Gurulev
Amendment -
QueryIOSurf works in h264_enc_filter sample (CEncVideoFilter class), but failed with MFX_ERR_INVALID_VIDEO_PARAM in sample_vpp even if exactly the same (bit-to-bit) mfxVideoParam is used. Soft or hard - doesn't matter.
Petter_L_Intel
Hi Dmitry,
Using your sample_vpp command line and replicating it here on my side it looks like the issue your encountering is due to using input surface type RGB3. This surface type is deprecated and not supported anymore (the sample usage description unfortunately still lists RGB3, this is a documentation error).
If you change your command to use for instance RGB4 (-scc rgb4) it should work fine.
Petter
Dmitry_Gurulev
Hi Peter,
As I see, Intel VPP supports nothing CC conversion except target is NV12 and source is YV12\YUY2. Where can I find the list of supported modes?
PS. What <mfxInfoVPP::ChromaFormat> is intended for? It seems to me VPP just ignore this field.
Dmitry_Gurulev
OK, I found list at mediasdk-man - Table 2: Color Conversion Support in VPP, page 6
Petter_L_Intel
Correct,  ChromaFormat is ignored for the vast majority of use cases.
