I'm able to run sample_vpp on an rgb4 input file. However, whether I make the output file rgb4 (via the -dcc option), or nv12 the output file is unplayable. The program seems to execute correctly and a file is written. However in GraphEdit the file has GUID = GUID_NULL. Is this by design?
Even if I make no changes (i.e. I don't use any of the options), the file is still unplayable and slightly shorter than the original file. Are there some headers not written??
mags
Hi Mags,
I am able to get do color conversion with sample_vpp and able to play the o/p. I am using a YUV player to play the o/p with the help of changing the color option.
There are few things I would like you to check
1. Can you try any basic test like frame rate or denoising and see if you are able to play the o/p.
2. Please let me know what all changes you have made in the code and please send us your input. If it's too big, you can share it through syncplicity.
-Surbhi
Hi:
here is my command line
sample_vpp.exe -lib hw -sw 640 -sh 480 -dw 640 -dh 480 -scc rgb4 -dcc nv12 -i a.avi -o nv12
The nv12 file is created, but I cannot play the file in any of the following programs:
Window Media Player, VLC, SourFourge's yuvplayer (dated 6/27/2014)
I made no modifications to sample_vpp, and in general the programs seems to work fine. So perhaps the feature (i.e. to write headers to the created file) is not there by design?
If you have a yuv file player you'd recommend (instead of SourFourge's) let me know.
Mags
Hi Steven,
You can use ffplay to play a nv12 input. With this you can play yuv,rgb,nv12 file.
To play nv12 format, use this cmd "ffplay.exe -s wxh -pix_fmt nv12 out.yuv"
VLC, windows media player needs container to play a file, due to which you are not able to play nv12 o/p.
Hope that will help.
-Surbhi
