Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
undefined symbol: drm_intel_gem_bo_unmap_wc
Arseniy_S_
Hello.
I'm trying to use hardware HEVC encoder of i5-7300HQ through FFMpeg 3.3.3 on GNU/Linux 4.12.4. Have MediaServerStudioEssentials2017R3 installed.
quicksync-video-ffmpeg-install-valid.pdf tells, that I need to load iHD libva driver. However, it seems to be incompatible with current i915 (or what?):
user@host ~ % LIBVA_DRIVERS_PATH=/opt/intel/mediasdk/lib64 LIBVA_DRIVER_NAME=iHD vainfo
libva info: VA-API version 0.40.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva error: dlopen of /opt/intel/mediasdk/lib64/iHD_drv_video.so failed: /opt/intel/mediasdk/lib64/iHD_drv_video.so: undefined symbol: drm_intel_gem_bo_unmap_wc
libva info: va_openDriver() returns -1
vaInitialize failed with error code -1 (unknown libva error),exit
It's intersting, that open-source i965 libva driver does show something I interpret as support for HEVC encoding:
      VAProfileHEVCMain               :	VAEntrypointVLD
      VAProfileHEVCMain               :	VAEntrypointEncSlice
      VAProfileHEVCMain10             :	VAEntrypointVLD
      VAProfileHEVCMain10             :	VAEntrypointEncSlice
So, my question is: why I'm not able to use hardware HEVC encoding? Non-4.4 kernel? Kaby Lake CPU? Or something else is wrong in the system (or SDK)?
Mark_L_Intel1
Hi Arseniy,
The Media Server Studio doesn't support Kaby Lake processors, you can check the following URL for the detail:
https://software.intel.com/en-us/forums/intel-media-sdk/topic/735307
Let me know if you have further questions.
Mark
Arseniy_S_
So, how we are supposed to use HEVC hardware encoding on Kaby Lake CPUs? Via VA-API?
Arseniy_S_
The answer is "Yes".
If anyone is intersted - see https://trac.ffmpeg.org/wiki/Hardware/VAAPI.
Mark_L_Intel1
Yes, you can still use open source kernel/VAAPI to use the HEVC encoding.
Mark
