Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
using PCIe with media sdk
rshal2
New Contributor II
Is there any information how to capture video stream through PCIe with Media SDK?
Ran
rshal2
New Contributor II
Hi Zachari,
DRM is for video display not capture so this is irrelevant for the issue which I opened.
As I mentioned, we need to capture video than send the captured frame into Intel Media SDK's encoder.
I wander if there is anyone who did video capture using "media sdk". I didn't find any example/document/reference for this issue.
Ran
Bjoern_B_Intel
Hi Ran,
are you asking for information regarding PCIe capture cards in combination with MSDK?
We don’t have information on this topic but let me see if we can get it included in the future.
Best,
Bjoern
rshal2
New Contributor II
Hi Bjoern,
Thank you for the quick response.
I am actually interested in two things here:
1. PCIe example with media sdk (if such example is available)
2.Any v4l (video4linux) example which shows how media sdk application read from /dev/videoX devices (camera for example)
Ran
Jiandong_Z_Intel
Hi Ran,
About Media SDK on Linux, the Kernel Mode Driver (KMD) is base on DRM framework, not v4l,  so the software stack as following
Application -> MSDK -> libva -> libdrm -> drm -> i915.ko
DRM framework and v4l are different in Linux kernel tree. I believe MSDK no samples focus on read frame or stream via v4l currently.
Are you want to read frame or stream from camera via v4l, then let MSDK process this frame or stream ?  if so, I think MSDK can process the frame or stream.
Zachary
rshal2
New Contributor II
Hi Zachary,
Is there any documentation or example about capturing frames/video from camera (or other device) ?
Ran
rshal2
New Contributor II
Hi Zachary,
I mean any example/document for capturing using the architecture used with media sdk  (DRM framework).
Ran
Jiandong_Z_Intel
Hi Ran,
Following pdf is good for understand DRM framework and v4l in my mind.
http://elinux.org/images/7/71/Elce11_dae.pdf
Zachary
rshal2
New Contributor II
Hi Zachary,
Is there any sample for media sdk which shows capturing using DRM framework ?
Ran
Jiandong_Z_Intel
Hi Ran,
No,  no media sdk sample can do this. And media sdk focus on media process (decode/vpp/encode).
Can you explain what is really you want to do ?
Are you want to develop a camera driver on Linux for capturing or do some media process after capturing ? or others ?
Zachary
rshal2
New Contributor II
Hi Zachary.
Yes.
We wanted to evaluate if we can use Media SDK with Linux/windows (Linux is prefered) for doing the following:
<raw video from camera>-----PCIe----- <Capture>-----<Encode>-------><File in DISK>
Ran
rshal2
New Contributor II
Hi Zachari,
Ran
Satish_P_
We are also trying for similar but not with V4L devices , we are using Decklink card for capture video
With Blackmagic driver we are able to capture and store video from Decklink Capture Card , now we want to use this captured Real time  data as input of MEdia SDK Encoder application.
but unfortunately Media sdk encodes this data once and then stop...
so is there any way to directly integrate Decklink card with Media SDK for real time encoding?
rshal2
New Contributor II
Hi Satish,
I've made a very simple changes in order to support v4l through the media samples. You should try, it's not too difficult.
Unfortunattely, it was not integrated as part of the media sdk which is supplied for linux users. I hope Intel will integrate it in next releases, becuase I think that many mediasdk users need such "realtime" feature.
Ran
