Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
3058 Discussions
vaInitialize failed and errors while running sample_decode
Sam1
I have built Intel Media SDK in Ubuntu 16.04 after patching the kernel as given in "http://docs.unified-streaming.com/documentation/capture/media-sdk.html#linux".
When I enter vainfo this is what I get:
libva info: VA-API version 0.99.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
DRM_IOCTL_I915_GEM_APERTURE failed: Invalid argument
Assuming 131072kB available aperture size.
May lead to reduced performance or incorrect rendering.
get chip id failed: -1 [22]
param: 4, val: 0
libva error: /opt/intel/mediasdk/lib64/iHD_drv_video.so init failed
libva info: va_openDriver() returns 18
vaInitialize failed with error code 18 (invalid parameter),exit
When I run sample_decode, it gives this error:
[ERROR], sts=MFX_ERR_UNSUPPORTED(-3), Init, m_mfxSession.Init failed at msdk/samples/sample_decode/src/pipeline_decode.cpp:285
The processor is Intel(R) Core(TM) i5-6400. Ubuntu 16.04 is run on VMware
Anna_B_Intel
Hi Nihadh,
Make sure that you loaded the proper Linux kernel. What's the output from "uname -r" command?
Best wishes,
Anna
Sam1
Output of uname -r:
4.4.0
This is the kernel that is required. Actually the problem was that I was running Intel Media SDK in VMware with Windows 10 host. I found out that virtual machines cannot access GPU especially when host is windows. That is why HW implementation failed. But why doesn't SW implementation work? I get the same error with SW implementation too.
