Community
cancel
Showing results for
Search instead for
Did you mean:
Chenglin_H_
vainfo dosen't work after installing MSS 2017 R2
My Env:
$ cat /etc/centos-release
CentOS Linux release 7.2.1511 (Core)
$ uname -a
Linux localhost.localdomain 3.10.0-327.el7.x86_64 #1 SMP Thu Nov 19 22:10:57 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
$ sudo lspci -nn -v -s 00:02.0
00:02.0 VGA compatible controller [0300]: Intel Corporation Sky Lake Integrated Graphics [8086:1912] (rev 06) (prog-if 00 [VGA controller])
	Subsystem: Dell Device [1028:06ba]
	Flags: bus master, fast devsel, latency 0, IRQ 7
	Memory at f6000000 (64-bit, non-prefetchable) [size=16M]
	Memory at e0000000 (64-bit, prefetchable) [size=256M]
	I/O ports at f000 [size=64]
	Expansion ROM at <unassigned> [disabled]
	Capabilities: [40] Vendor Specific Information: Len=0c <?>
	Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
	Capabilities: [ac] MSI: Enable- Count=1/1 Maskable- 64bit-
	Capabilities: [d0] Power Management version 2
	Capabilities: [100] #1b
	Capabilities: [200] Address Translation Service (ATS)
	Capabilities: [300] #13
$ lscpu
Architecture:          x86_64
CPU op-mode(s):        32-bit, 64-bit
Byte Order:            Little Endian
CPU(s):                4
On-line CPU(s) list:   0-3
Thread(s) per core:    1
Core(s) per socket:    4
Socket(s):             1
NUMA node(s):          1
Vendor ID:             GenuineIntel
CPU family:            6
Model:                 94
Model name:            Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz
Stepping:              3
CPU MHz:               800.000
BogoMIPS:              6382.07
Virtualization:        VT-x
L1d cache:             32K
L1i cache:             32K
L2 cache:              256K
L3 cache:              6144K
NUMA node0 CPU(s):     0-3
Follow these steps:
$ sudo usermod -a -G video $USER
$ sudo sh -c "sed -i -e 's/mirrorlist=/#mirrorlist=/g' /etc/yum.repos.d/CentOS-Base.repo"
$ sudo sh -c "sed -i -e 's/#baseurl=http:\/\/mirror.centos.org\/centos/baseurl=http:\/\/vault.centos.org/g' /etc/yum.repos.d/CentOS-Base.repo"
$ sudo ./install_sdk_CentOS.sh
[sudo] password for mm:
checking whether --releasever=7.2.1511 works for yum...
Loaded plugins: fastestmirror, langpacks
Loading mirror speeds from cached hostfile
checking PASSED!
There is no installed groups file.
Maybe run: yum groups mark convert (see man yum)
http://mirror.centos.org/centos/7.2.1511/os/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
Trying other mirror.
To address this issue please refer to the below knowledge base article
https://access.redhat.com/articles/1320623
If above article doesn't help to resolve this issue please create a bug on https://bugs.centos.org/
 One of the configured repositories failed (Unknown),
 and yum doesn't have enough cached data to continue. At this point the only
 safe thing yum can do is fail. There are a few ways to work "fix" this:
     1. Contact the upstream for the repository and get them to fix the problem.
     2. Reconfigure the baseurl/etc. for the repository, to point to a working
        upstream. This is most often useful if you are using a newer
        distribution release than is supported by the repository (and the
        packages for the previous distribution release still work).
     3. Disable the repository, so yum won't use it by default. Yum will then
        just ignore the repository until you permanently enable it again or use
        --enablerepo for temporary usage:
            yum-config-manager --disable <repoid>
     4. Configure the failing repository to be skipped, if it is unavailable.
        Note that yum will try to contact the repo. when it runs most commands,
        so will have to try and fail each time (and thus. yum will be be much
        slower). If it is a very temporary problem though, this is often a nice
        compromise:
            yum-config-manager --save --setopt=<repoid>.skip_if_unavailable=true
Cannot find a valid baseurl for repo: extras/7.2.1511/x86_64
        compromise:
        compromise:
warning: intel-opencl-cpu-r4.0-59481.x86_64.rpm: Header V4 RSA/SHA1 Signature, key ID 13881d9c: NOKEY
Preparing...                          ################################# [100%]
Working. This may take some time ...
Done.
Installing kmod-ukmd-16.5.1-59511...
Updating / installing...
   1:kmod-ukmd-16.5.1-59511.el7       ################################# [100%]
Done.
Installation done.
$ sudo reboot
$ ls /opt/intel/mediasdk/
doc  include  lib  lib64  opensource  plugins  tools
$ lsmod | grep 'i915'
i915                 1325693  0
i2c_algo_bit           13413  1 i915
drm_ukmd_kms_helper   141060  1 i915
drm_ukmd              369649  2 i915,drm_ukmd_kms_helper
drm_ukmd_compat       109279  1 i915
video                  24400  1 i915
i2c_core               40582  7 drm,i915,i2c_i801,i2c_hid,i2c_algo_bit,drm_ukmd,drm_ukmd_kms_helper
$ ll /dev/dri
ls: cannot access /dev/dri: No such file or directory
$ vainfo
libva info: VA-API version 0.99.0
Xlib:  extension "XFree86-DRI" missing on display ":0".
libva info: va_getDriverName() returns -1
libva error: va_getDriverName() failed with unknown libva error,driver_name=(null)
vaInitialize failed with error code -1 (unknown libva error),exit
Now I don't know how to make it work.
Any help would be appreciated!
Chenglin_H_
I have solved it. I ran sys_analyzer_linux.py(https://software.intel.com/en-us/articles/mss-sys-analyzer-linux)  and found that the system boots with nomodeset parameter. After removing nomodeset, it works fine.
