Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
vainfo error with ssh
verma__Ashish
I am trying to initialize mediasdk(libva, iHD driver) in a remote machine using ssh, but I am getting this error -
get chip id failed: -1 [13]
param: 4, val: 0
libva error: /opt/intel/mediasdk/lib64/iHD_drv_video.so init failed
libva info: va_openDriver() returns 1
terminate called after throwing an instance of 'std::bad_alloc'
  what():  std::bad_alloc
If I am directly running on the machine itself, It's happily running.
I have also set the environment variables related to libva
export DISPLAY=:0
export LIBVA_DRIVER_NAME=iHD
export LIBVA_DRIVERS_PATH=/opt/intel/mediasdk/lib64
I have search a lot about this issue but not able to figure out this behaviour.
I am using vainfo: VA-API version: 1.3 (libva 2.3.0) on ubuntu 16.04.5 LTS
Any help will be appreciated
Ashish
Dmitry_E_Intel
I'd advise to submit an issue here: https://github.com/intel/media-driver/
But right here, I'd recommend to check that i915 is loaded:
"lsmod | grep i915"
"dmesg | grep i915"
You may also try to run 'vainfo' under 'strace' to check which low level call(s) exactly fails.
Mark_L_Intel1
Hi Ashish,
This should be expected since SSH normally doesn't have graphic enabled.
Normally Media SDK required the graphic driver active to access hardware accelerated codec.
Could you try a graphic remote access like VNC to double check?
Mark
