I can't get Media SDK to work. vainfo seg faults trying to write to 0x18.
Here' s my install steps:
Install fresh Ubuntu 14.10
# Add necessary components
sudo apt-get install build-essential git yasm cmake libtool libc6 libc6-dev
# Intel Graphics Stack Installer
# https://01.org/linuxgraphics/downloads
wget --no-check-certificate https://download.01.org/gfx/RPM-GPG-KEY-ilg -O - | sudo apt-key add -
wget --no-check-certificate https://download.01.org/gfx/RPM-GPG-KEY-ilg-2 -O - | sudo apt-key add -
wget https://download.01.org/gfx/ubuntu/14.10/main/pool/main/i/intel-linux-graphics-installer/intel-linux...
sudo dpkg -i intel-linux-graphics-installer_1.1.0-0intel1_amd64.deb
sudo apt-get update
sudo intel-linux-graphics-installer
# Install Intel Media Framework SDK
tar xfp mediaserverstudioessentials2015r6.tar.gz
pushd MediaServerStudioEssentials2015R6
tar xfp SDK2015Production16.4.2.1.tar.gz
cd SDK2015Production16.4.2.1
cd Generic
tar xfp intel-linux-media-ocl_generic_16.4.2.1-39163_64bit.tar.gz
sudo ./install_media.sh
popd
# repair Intel Media SDK missing installation parts
sudo ln -s /opt/intel/mediasdk/include /usr/local/include/mfx
sudo mkdir /usr/local/lib/pkgconfig/
sudo cp libmfx.pc /usr/local/lib/pkgconfig/
sudo ldconfig
lab@lab-X10SAE:~/$ cat libmfx.pc
prefix=/opt/intel/mediasdk exec_prefix=${prefix} libdir=${exec_prefix}/lib/lin_x64 libdir2=${exec_prefix}/lib64 includedir=${exec_prefix}/include Name: libmfxhw64 Description: Intel Media SDK dispatcher. Version: 2015r3 Libs: -L${libdir} -lmfx -L${libdir2} -lva -lva-drm -ldrm -lstdc++ -ldl Cflags: -I${includedir}
lab@lab-X10SAE:~$ vainfo
libva info: VA-API version 0.37.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
Segmentation fault (core dumped)
lab@lab-X10SAE:~$ gdb vainfo
GNU gdb (Ubuntu 7.8-1ubuntu4) 7.8.0.20141001-cvs
Copyright (C) 2014 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from vainfo...done.
(gdb) run
Starting program: /usr/bin/vainfo
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff47272eb in ?? () from /opt/intel/mediasdk/lib64/iHD_drv_video.so
(gdb) bt
#0 0x00007ffff47272eb in ?? () from /opt/intel/mediasdk/lib64/iHD_drv_video.so
#1 0x00007ffff7bc48b8 in ?? () from /usr/lib/x86_64-linux-gnu/libva.so.1
#2 0x00007ffff7bc5700 in vaInitialize () from /usr/lib/x86_64-linux-gnu/libva.so.1
#3 0x0000000000400edc in main (argc=<optimized out>, argv=<optimized out>) at vainfo.c:107
(gdb)
Hi There,
Following topic maybe can help you -
https://software.intel.com/en-us/forums/topic/543365
https://software.intel.com/en-us/forums/topic/562610
Zachary
