Hi all,
I tried video resize and pixel format convert with sample_vpp_drm. I found the performance of vpp is lower than ffmpeg.
I have a raw video, whose pixel format is yv12, and 500 frames.
First, use sample_vpp_drm like this:
time ./_bin/x64/sample_vpp_drm -lib hw -sw 1920 -sh 1080 -scc yv12 -spic 1 -sf 25 -dw 720-dh 576-df 25 -dcc nv12 -dpic 1 -i ./input_yv12.yuv -o /dev/null
run it ten times, and get the average clock of the last four times:
0m2.982s,0m2.987s,0m2.986s,0m2.987s
so, the vpp fps is 167.
second, use ffmpeg like this:
time ~/ffmpeg -s 1920x1080 -pix_fmt yuv420p -i ./input_yv12.yuv -s 720x576 -pix_fmt nv12 -f rawvideo -y /dev/null
0m2.666s,0m2.621s,0m2.623s,0m2.607s
so, the vpp fps is 190.
But if the output is 1280x720, vpp;s performance is higher than ffmpeg
CPU:Intel(R) Core(TM) i7-4770R CPU @ 3.20GHz
Hello Yabo,
Thanks for sharing your results, apologies it took us a while to get to your question. I tried to reproduce the results you mention above with the command-line you shared. On the latest Media Server Studio product (16.4 release for CentOS 7.0, with samples version MediaSamples_Linux_5.0.1604371.71 - http://software.intel.com/sites/default/files/managed/df/17/MediaSamples_Linux_5.0.1604371.71.tar.gz), the performance of Media SDK is better than FFMPEG (Dec 23 2014 release).
I recommend you update to the latest Media SDK product and let us know what you observe. And/or more details on the system config for your experiment.
