Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
2966 Discussions
where is the example of "transcoding with picture-in-picture"
makefriend8
https://github.com/Intel-Media-SDK/MediaSDK/blob/master/doc/mediasdkusr-man.md said Figure 1 shows three usage example.
where is the code ?
ChithraJ_Intel
Hi Mars,
Thanks for your patience. We have discussed your query with Subject Matter Experts. Based on this, we could understand that there is no specific sample for transcoding which you mentioned. The given developer manual(mediasdkusr-man.md) describes an API extension that allows user-defined functions into the transcoding pipeline using Media SDK. Simply, you have to develop the code yourself for that example based on API's described in the manual. Sorry for the inconvenience caused.
Since the sample is not available, can we discontinue monitoring this thread?
Chithra
ChithraJ_Intel
Hi Mars,
Thanks for posting in Intel Community Forums.
The available opensource MediaSDK sample in GitHub for transcoding is sample_multi_transcode. Here is the link for the sample:
https://github.com/Intel-Media-SDK/MediaSDK/tree/master/samples/sample_multi_transcode
Could you please confirm whether you are referring to the above mentioned sample or not? If so, you can refer to the readme file available in the below link for more details:
https://github.com/Intel-Media-SDK/MediaSDK/tree/master/doc/samples
Otherwise, We will contact with concerned team to solve your issue.
Chithra
ChithraJ_Intel
Hi Mars,
Chithra
ChithraJ_Intel
Hi Mars,
Thanks for the confirmation. We would discontinue monitoring this thread. Please raise a new thread if you have any issues/queries.
Chithra
