- Email to a Friend
which media sdk recommended for encoding 8 SDI video HD sources simultaneously
with better performance quality CBR and low latency
using the following HW :
5th Generation Intel® Core™ i7 Quad Core @ 2.6GHz (Broadwell)
HD Graphics 5600
and with OS windows 7
Media SDK for client 2016 or Media server SDK or maybe the INDE framework
do you think maybe it is necessary to upgrade the core cpu to skylake or/and the HD Graphics or the OS ?
thanks
- Email to a Friend
Hi erez,
What is the codec of 8 SDI video HD?
In general, your chip should support HW codec. The way to check it:
1. Take the serial number of the chip(you can read it by CPU-Z)
2. Go to ark.intel.com and search the chip serial
3. In the result, looking for Graphic spec item "Intel® Quick Sync Video", if yes, it means the hardware codec is supported.
You can use either MSDK or MSS, both should work. It is better to use SkyLake to have more room for performance.
Let me know if you have more questions.
Mark
