Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
which media sdk recommended for encoding
erez_a_
which media sdk recommended for encoding 8 SDI video HD sources simultaneously
with better performance  quality CBR and low latency
using the following HW :
5th Generation Intel® Core™ i7 Quad Core @ 2.6GHz  (Broadwell)
HD Graphics 5600
and with OS  windows 7
Media SDK for client 2016  or Media server SDK  or maybe the  INDE framework
do you think maybe it is necessary to upgrade the core cpu to skylake or/and  the HD Graphics  or the OS ?
thanks
Mark_L_Intel1
Hi erez,
What is the codec of 8 SDI video HD?
In general, your chip should support HW codec. The way to check it:
1. Take the serial number of the chip(you can read it by CPU-Z)
2. Go to ark.intel.com and search the chip serial
3. In the result, looking for Graphic spec item "Intel® Quick Sync Video", if yes, it means the hardware codec is supported.
You can use either MSDK or MSS, both should work. It is better to use SkyLake to have more room for performance.
Let me know if you have more questions.
Mark
