1. 问题描述
在常规作系统电源状态转换过程中(如:系统睡眠唤醒、AC/电池电源切换、USB设备热插拔),设备会随机触发 蓝屏。关键技术特征如下:DRIVER_POWER_STATE_FAILURE (9F)
- 崩溃模块:
- 阻塞驱动: (版本:[您的驱动版本])iaLPSS2_I2C_MTL.sys
- 关联组件:pci.sys
- 崩溃参数:
Arg1: 0000000000000003 (电源操作超时) Arg2: ffffe00f3a7c0600 (iaLPSS2_I2C_MTL驱动对象) Arg3: fffff8076a6c5190 (阻塞的IRP)
- 复现场景:
该问题在标准系统作流程中可稳定触发:m复制代码graph LR A[系统睡眠] --> B[等待30秒] B --> C[按电源键唤醒] C --> D{蓝屏概率 >70%}
2. 诊断证据
我们已收集以下技术数据供分析:
- 系统配置:
- 处理器:Intel Core Ultra [型号]
- 芯片组:Intel [芯片组型号]
- BIOS版本:[BIOS版本]
- 关键日志:
- Windows事件ID 41:内核能力 (CRITICAL)
- ACPI错误:_PS0执行超时
- 驱动栈分析:
DRIVER_POWER_STATE_FAILURE (9f) !dpx -d 0xffffe00f3a7c0600 # Child-SP Call Site 00 fffff807`6a6c5190 iaLPSS2_I2C_MTL+0x3a50 01 fffff807`6a6c51d0 nt!KiProcessTimerDpcTable 02 fffff807`6a6c5220 nt!KiRetireDpcList
3. 请求支持
基于问题对系统基础功能的严重影响,恳请协助:
驱动验证:
- 确认该问题是否与已知缺陷相关(如Intel内部追踪ID)
- 提供适用于Meteor Lake平台的iaLPSS2_I2C_MTL热修复驱动
技术指导:
- 建议的临时缓解措施(不涉及禁用系统电源管理功能)
- PCIe ASPM/L1.2状态配置的优化参数
升级路径:
- 若需硬件协同调试,请提供本地FAE联系方式
- 建议的BIOS/FW更新策略
Hello 笙汐,
请注意,我只能用英语为您提供支持。我使用了网络翻译工具来翻译此回复,因此,可能会有一些不准确的翻译。
To effectively address your concern, please share the information below.
1. Was this working fine before?
2. Did you make recent changes to the system?
3. Does the issue occur consistently?
Additionally, to have a better understanding of your system configuration and components please generate System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
Best regards
Jed G.
Functionality: It has never worked properly; issues began shortly after purchase.
System Changes: No major changes (hardware/OS/software) have been made.
Consistency: Constant Blue Screen errors (BSOD) occur persistently.
Hello 笙汐,
Thank you for sharing all this information.
To further troubleshoot the issue, please try to follow the outlined steps below.
1. Update the BIOS - Kindly check with your OEM
2. Check for Windows Updates
3. Test your RAM and hard drive for errors using tools like MemTest86 and CHKDSK.
4. Check for graphics driver update.
If the same issue persists, kindly provide the exact link for your laptop so we can investigate further.
Best regards
Jed G.
Hello 笙汐,
I wanted to check if you had the chance to review the recommendations I posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Jed G.
Hi 笙汐,
About the OEM driver, you may find this link helpful - https://www.honor.com/my/support/downloads/?srsltid=AfmBOorFYl1B8ZZ0mjNXQ4F5H1qGapXumFUNNobdAGfVBqt2tnNLNuR6
Also, since I have not heard back from you so I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Jed G.
