16927 Discussions
14600k normal voltage??
Reza093
hi
i purchased a new pc and here is the config below:
os: windows 11 pro
cpu:i5 14600k
gpu: gtx1080
mb:z790ud (gigabyte)
ram: 16 g ddr5 4800 MT
i noticed my cpu voltage VID(MAX) going around(1.339-1.346 v)  when iam playing games like (apex or bf2042). and lowest voltage is at (1.284) for the idle time and i dont have any crash problem with any games. yet i am concerned with the voltage that maybe damage my cpu
 and yesterday i updated my motherboard bios to the latest version that contain129 microcode(F12e) also i did a reset on whole bios setting and intel default setting  should be enabled as the motherboard manufacture said its enabled by default  and i didn't overclock anything and its run by default setting also my cpu temp is around 54°C at game.
so my question is : my cpu voltage is normal ? and if its not normal what should i do to prevent from cpu damage?
n_scott_pearson
Your voltages look just fine. Now that the update is installed, you should be protected against any possibility of voltage-based damage -- if you have the Intel configuration selected. Now, most BIOSs are designed such that the configuration persists across updates. This means that the configuration you had previously may still persist. I thus recommend going into BIOS Setup and verifying that the Intel configuration is selected.
Hope this helps,
n_scott_pearson
Hope this helps,
