Hello, I want to build a new computer, but I am indecisive to buy the 14700K due to the temperature issues I’ve heard about. I’ve heard that some customers have returned the processor.
I have selected the following components:
Components:
Intel i7 14700K
MSI MAG Z790 TOMAHAWK DDR5
Patriot Viper 2x32 GB DDR5 6000 MHz
GALAX RTX 4070ti Super 16G
MSI CoreLiquid 360R v2
Could anyone (Intel) please answer my questions below?
Q1- I noticed that the 0x12B Micro Code update was released on MSI's official website. Will just applying this update definitely fix the high voltage and high temperature (100°C) issues with the 14700K?
Q2- If I only apply the 0x12B Micro Code update, what will the maximum processor temperature be when all cores are under full load (Cinebench etc.)?
Q3- Is the 0x12B Micro Code update essential for undervolting?
Q4- Do I have to perform undervolting?
Q5- Will undervolting prevent the processor from getting damaged?
Q6- How should I perform undervolting on the MSI MAG Z790 TOMAHAWK DDR5 motherboard? What parameters should I change in the BIOS? Is there a guide for this?
Q7- Will the system be absolutely stable with undervolting?
Q8- Will undervolting cause any performance loss?
Q9- If I apply the 0x12B Micro Code update and undervolting, what will the maximum processor temperature be when all cores are under full load (Cinebench etc.)?
Q10- After applying the 0x12B Micro Code update and undervolting, can I be sure that the processor won’t be damaged after a while?
Q11- Was the Intel i7 14700K processor produced with defects? Were there errors in its manufacturing?
I am sure users of the 14700K processor and potential buyers of the 14700K are curious about the answers to these questions.
The 0x12B Microcode update from MSI is designed to address certain power management and stability issues that have been observed in some 14700K processors. It may help to improve voltage regulation and potentially lower temperatures in some cases. However, it's not a guaranteed solution for all temperature-related issues. visit this intel link for more details Intel Core 13th and 14th Gen Desktop Instability Root Cause Update
For question 2, without the 0x12B update and undervolting, temperatures under full load (like Cinebench) can vary significantly depending on factors such as Cooling solution, Ambient temperature, Workload. With just the 0x12B update, maximum temperatures under full load are expected to be lower than without it, but the exact range will depend on the factors mentioned above.
For Q3, The 0x12B Microcode update is not essential for undervolting. Undervolting is a separate process that can be performed regardless of the Microcode version.
For Q4, well undervolting is generally recommended for improving CPU temperatures and potentially increasing overclocking headroom. It involves reducing the voltage supplied to the CPU while maintaining stability.
