4790 temp
dalex4
Hello I have a 4790 processor.
My temperature when pc idle is 35c, I believe that is too high.
I check the installation of the CPU fun and it's ok.
Could you help me?
When I play simple games temp goes to 50c+ (world of battleship)
Room temp 20c
AP16
Valued Contributor III
Idle temperature is normal for such CPU. Throttling temperature is 72.7 C, so until you hit more that 65C there is nothing to care about.
IUman
JFFulcrum is correct, there is nothing to worry about that temperature and it is totally normal for this CPU.
You can see the TCASE (case temperature) of 72.72°C here:
http://ark.intel.com/products/80806/Intel-Core-i7-4790-Processor-8M-Cache-up-to-4_00-GHz Intel® Core™ i7-4790 Processor (8M Cache, up to 4.00 GHz) Specifications
