17158 Discussions
7700k Overheating..temp always above 60
AAugu5
i have a i7 7700k pro and temp is above 61 ..only using chrome..why is this pls help me
spec:
no graphics card
gskill tridentz RGB 16gb
cooler master MasterLiquid Pro 280
Msi z270 gaming m7
AlbertAug: Thank you very much for contacting the Intel® Processors communities. We will do our best in order to try to fix this problem.
In regard to your inquiry, actually the temperature your processor is showing is normal and expected. The T-junction of the Intel® i7-7700K is 100°C, any temperature below that value is considered normal. In this case, if the processor reaches 90°C that will be risky but 60°C is not a problem:
http://ark.intel.com/products/97129/Intel-Core-i7-7700K-Processor-8M-Cache-up-to-4_50-GHz http://ark.intel.com/products/97129/Intel-Core-i7-7700K-Processor-8M-Cache-up-to-4_50-GHz
Now, is the PC throttling, getting freeze or shutting down by itself?
We can also run the Intel® Processor Diagnostics tool, it will do an overall test on it including a temperature test and if the processor passed the test then it should be fine:
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool
Any further questions, please let me know.
Alberto R
AlbertAug: I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Alberto R
