17147 Discussions
ARL VRTT测试FVM 测试issuse
Alice_
Dear Sir:
目前在进行VRTT测试FVM测项测试,跑Fast_VMode_Example脚本时,遇到了下述报错,请帮忙确认该如何解决。(ps:3D_4L_MTPMax_VID1_VID2脚本已顺利跑完,且结果pass)
Traceback (most recent call last):
File "C:\Program Files\Intel\UPDT\PythonScripts\Fast_VMode_Client_UPDT_93.py", line 1794, in <module>
data_labels = get_data_labels(test_voltage, test_icc_max, worst_max_dv_all_runs_icc_idx, max_dv_cycle_num, offset=start_row)
File "C:\Program Files\Intel\UPDT\PythonScripts\Fast_VMode_Client_UPDT_93.py", line 1034, in get_data_labels
if output_data[test_voltage][test_icc_max]["third_droop_idxs"][run_number][cycle_num] > 0:
TypeError: '>' not supported between instances of 'NoneType' and 'int'
专案schedule较赶,请帮忙尽快回复~
感谢~
Alice_
any update?
Alice_
Can someone help answer this question?
Earl_Intel
Hi Alice_,
请注意,我只能用英语为您提供支持,或者如果您愿意,我可以将您转移到支持您语言的其他团队。我使用了网络翻译工具来翻译此回复,因此,可能会有一些不准确的翻译。
Please supply the information requested here so that we can better assist you and identify the best course of action:
  • Can you clarify what exact issue are you experiencing? Can you provide us a screenshot or a short video clip of the issue?
Kindly run this on your system so that I can also gauge the following peripherals and the driver versions that you have:
Intel® System Support Utility for Windows*
Once finished downloading, open the tool, click on scan (leave the default items checked), click next, then save the system information to a .txt file. Please provide us the .txt file.
Earl E.
Alice_
Hi Earl:
Thank you for your response. Currently, I am encountering a test issue while running the INTEL test item FVM(VCCIA).
Reference document: 644954_Fast_VMode_Val_UG_Rev1p8
Test platform: VRTT ARL 65W
Test script: The test scripts for VCCSA and VCCIA are attached.
Test issue: When running the VCCSA test item using this script, the test proceeds normally. However, when using the same script and changing the power rail to VCCIA and modifying the current, the test cannot continue normally and an error occurs as shown in the attached image.
How can I fix this error?
Looking forward to your reply~
Alice
Earl_Intel
Hi Alice_,
Thank you for sharing this information with us.
No worries, I will further check on this internally and see what I can do.
I'll provide an update on this thread as soon as possible.
Earl E.
Earl_Intel
Hi Alice_,
Thank you for patiently waiting on us.
Seems like your concern is handled by our Intel Design In Tooms Team. You can contact them particularly for the VR Test Tool.
To contact them, try this:
Source link: How to Get Support for Intel® Design-In Tools Store
Earl E.
