16582 Discussions
Bom dia! Nao consigo fazer a verredura do meu sistema com o suport assistent, aparece a seguinte mensagem todas as vezes que tento: Opa! Alguma coisa deu errado durante a varredura. Tente novamente ou veja as perguntas frequentes para obter ajuda.
DBene11
AlHill
You are on Windows 10, version 1511, from November 2015.
Update to version 1903: https://www.microsoft.com/en-us/software-download/windows10
Also, your (cedarview) processor and graphics are not supported on Windows 10:
https://ark.intel.com/content/www/us/en/ark/products/59682/intel-atom-processor-d2500-1m-cache-1-86-ghz.html
https://www.intel.com/content/www/us/en/support/articles/000006105/processors.html
If you are looking for the Intel Driver and Support Assistant (IDSA) to help you with driver updates, you will be unsuccessful.
There are no drivers for windows 10. What drivers there are can be found under "downloads and software" on this link:
Doc
AlHill
Clear your browser cache.
What OS are you using? If Windows 10, are you using version 1903?
What browser are you using?
Is this a laptop or desktop?
Doc
DBene11
System Information
   Time of this report: 9/14/2019, 18:56:21
       Machine name: DESKTOP-TH2OBB8
     Operating System: Windows 10 Pro 64-bit (10.0, Build 10586) (10586.th2_release_sec.170913-1848)
         Language: Portuguese (Regional Setting: Portuguese)
   System Manufacturer: To be filled by O.E.M.
       System Model: A14CT
           BIOS: BIOS Date: 03/27/12 11:07:23 Ver: 04.06.05
        Processor: Intel(R) Atom(TM) CPU D2500  @ 1.86GHz (2 CPUs), ~1.9GHz
          Memory: 2048MB RAM
   Available OS Memory: 2036MB RAM
        Page File: 1898MB used, 777MB available
       Windows Dir: C:\WINDOWS
     DirectX Version: 11.2
   DX Setup Parameters: Not found
     User DPI Setting: Using System DPI
    System DPI Setting: 96 DPI (100 percent)
     DWM DPI Scaling: Disabled
         Miracast: Not Available
Microsoft Graphics Hybrid: Not Supported
      DxDiag Version: 10.00.10586.0000 64bit Unicode
AlHill
Doc
DBene11
Já apaguei o cache do browser mas o problema persiste
AlHill
upgrade to 1903 as I told you. Then, try again. However, it will really not matter.
Doc
DBene11
desatualizar o windows para a versão 7 seria melhor para o meu computador?
AlHill
I doubt it. The best thing for you to consider is getting a new or newer system that is supported on Windows 10.
Doc
