- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Hello
Did diagnostics and found the error
Help me understand what the problem is
The full text of the error:
--- IPDT64 - Revision: 3.0.0.23.W.MP
--- IPDT64 - Start Time: 15.02.2016 23:02:05
Processor 1
Intel(R) spbc Module Test
Module Version: 1.0.7.64b.W
Start Time: Mon Feb 15 23:02:05 2016
Test Result - PASS
..!!..Processor under test is verified as 'PRODUCTION'..!!..
Processor Manufacturer: GenuineIntel
Processor Brand String: Intel(R) Core(TM) i5-4670 CPU @ 3.40GHz
End Time: Mon Feb 15 23:02:05 2016
Total Time: seconds: 0
Genuine Intel CPU Test
Module Version: 1.0.12.64b.W
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
Temperature Test
Start Time: Mon Feb 15 23:02:06 2016
Test Result - PASS
Expected: Greater than 1 degrees below max
Received: 40 degrees below max
End Time: Mon Feb 15 23:02:06 2016
CPU Brand String Test
Test Result - PASS
Expected String Parts: As Defined in BrandString_LocalConfig.xml
Detected: Intel(R) Core(TM) i5-4670 CPU @ 3.40GHz
Module - CPUFreq.exe did not create a results file.
--- IPDT64 - Temperature Monitor Results
Temperature Monitor will begin when CPULoad Test starts
Temperature Monitor Stopped
System Information
Processor Name: Intel(R) Core(TM) i5-4670 CPU @ 3.40GHz
Processor Information: Intel64 Family 6 Model 60 Stepping 3
Number of Physical Cores: 4
Number of Logical Cores: 4
Installed System Memory: 8 GB
Operating System: Майкрософт Windows 10 Pro 64-разрядная
Graphics Information: NVIDIA GeForce GTX 770
System Product: H81M-HD3
System BIOS: F7
System Serial Number: To be filled by O.E.M.
--- IPDT64 - End Time: 15.02.2016 23:02:06
--- IPDT64 - Result: Fail
FAIL
- Tags:
- CPU
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
It seems to be a problem with the software version.
Have you tried bootable IPDT version?
http://www.tcsscreening.com/files/users/IPDT_LiveUSB/index.html Intel Processor Diagnostic Tool
Allan.
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Allan.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thanks for the reply.
Already figured out, the problem was Intel Processor Diagnostic Tool.
Actually my CPU is all right
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
