17153 Discussions
CPU cores utilization or usage
mNakh
hello there... i'd like to know why CPU cores utilization or usage is different and is not equal.... for example why one core is 15% and the next is 5%?
thank you very much
Jose_H_Intel1
Hello and welcome to Intel Communities.
The difference in utilization across cores depends on the following:
  • Different applications will make use of more or less CPU than others.
  • The operating system determines how the applications are assigned to CPU cores.
  • Applications may or may not take advantage of multiple core architecture; this depends on whether or not they were programmed to do so.
mNakh
mNakh
But please explain more if it's possible for you.
I'd like to know in processing time if we look at performance tab in task manager, it shows cores usage in different percent. For example one is 15% and at the same tine the other core usage is different.
Jose_H_Intel1
The following articles might further explain the concepts.
mNakh
Thanks a lot Mr. Joe... I got my answer... but I've still one more question... sorry to disturb you..
my last question is what does the CPU do when it is free and no application is running?
regards- Mojtaba
Jose_H_Intel1
It depends on the operating system power management settings but it is expected the processor clock speed will drop down when inactive, in order to save power.
