17152 Discussions
CPU frequency Fail i7-6700k
DGust2
Hi!
is it normal that the test fails on CPU frequency? or is there something wrong with my CPU? in the task manager the cpu work up to 4.1Ghz on load
EDIT: i manage to find a older version IPD 2.20 and that show pass on everything?
--- IPDT64 - Revision: 3.0.0.23.W.MP
--- IPDT64 - Start Time: 2016-02-07 13:40:22
Processor 1
Genuine Intel CPU Test
Module Version: 1.0.12.64b.W
Start Time: Sun Feb 07 13:40:22 2016
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
End Time: Sun Feb 07 13:40:22 2016
Total Time: seconds: 0
Temperature Test
Test Result - PASS
Expected: Greater than 1 degrees below max
Received: 48 degrees below max
CPU Brand String Test
Test Result - PASS
Expected String Parts: As Defined in BrandString_LocalConfig.xml
Detected: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
Module - CPUFreq.exe did not create a results file.
--- IPDT64 - Temperature Monitor Results
Temperature Monitor will begin when CPULoad Test starts
Temperature Monitor Stopped
System Information
Processor Name: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
Processor Information: Intel64 Family 6 Model 94 Stepping 3
Number of Physical Cores: 4
Number of Logical Cores: 8
Installed System Memory: 8 GB
Operating System: Microsoft Windows 10 Home 64 bitar
Graphics Information: AMD Radeon HD 6900 Series
System Product: MAXIMUS VIII HERO
System BIOS: 1402
System Serial Number: System Serial Number
--- IPDT64 - End Time: 2016-02-07 13:40:22
--- IPDT64 - Result: Fail
FHeik
New Contributor II
This appears to be a bug in the current version of IPDT.
If you run CPUFreq.exe parameterized from the command line, it works just fine, and writes the result file as expected.
DGust2
FHeik
New Contributor II
Just read the included PDF ... it describes all the command line options for any utility included in IPDT.
