16800 Discussions
Celeron 335 Temperature
Vegan
My web appliance uses a Celeron 335, the machine is an Acer Aspire T320.
I noticed that the CPU runs warm at 65C even when loaded.
I regreased the CPU fan when I replaced it as the existing was too noisy. Still runs just as warm whether using the copper or the replacement aluminum cooler.
Thoughts?
DSilv11
Valued Contributor III
Most likely your fan speed is controlled by the CPU temp and it is set to hold at 65degC.
a bit warm, but not outrageous.
Replacing the heatsink or fan with a high efficiency unit would then let the fan run slower (and quite) and the temp stays the same.
Vegan
The BIOS has an alarm, and the lowest it will go is 95C.
So far the machine is stable, so I guess I will make do with the fan I have until I find a better one.
