16574 Discussions
Core i7-12700F 2.10 GHz reaching 100 celsius while gaming
Efe_Fiskeci
Just bought and built my first PC, and I'm using the stock fan as CPU cooler. PC seems to work fine, temps are normal (35 celsius for the CPU while waiting at the desktop, 30 for the GPU), tried to boot up Bioshock 2 on max settings to check the gaming performance.
CPU reached 100 celsius in about 2 minutes, went down to 40 in a minute when i shut the game down.
Should I be worried about the temp, if so what steps should I follow?
My specs:Core i7-12700F 2.10 GHz
ASUS Prime B760M-K D4 motherboard
NVIDIA Geforce RTX 4070 Super
32 GB RAM
VARADHARAJAN
Valued Contributor II
@Efe_Fiskeci
Since you have 4070, so you should not use a stock cooler, instead use an AIO  360 liquid cooling system, and add additional case fans if your cabinet supports it.
Also set game graphics settings as High or Medium, and graphics advanced settings set possible options to low or off. Keep these settings for all the games
Varadharajan K
