Demarrage i7 12700 F
Sebastian6
Bonjour,
Je viens de finir de monter mon 1er PC avec un processeur i7 12700F et une carte graphique RTX 3060.
Malheureusement lorsque je demarre le PC, il n'y a pas d'affichage d'écran.
AlHill
Check your bios video settings
Update your bios.
Sebastian6
Je n'ai pas acces au bios.
J'ai juste un ecran noir au demarrage.
Jose_Intel
Hello @Sebastian6
Thank you for posting on the Intel️® communities.
We understand the issue with the Intel® Core™ i7-12700F Processor, let us help you.
Please provide us with the following:
  • Motherboard make and model.
  • Part number of the RAM.
Let’s check this:
  • Try to check a different PCIe* socket from the motherboard; if another PCIe socket works, refer to the motherboard manufacturer.
  • Start with the minimal hardware in your system, such as power supply, one DIMM of memory.
  • Clear the CMOS (complementary metal-oxide-semiconductor). Review instructions on how to clear the CMOS.
  • If there are no lights on the motherboard, try to use a different working motherboard if you have one.
If this a new processor, or new DRAM, ensure they are compatible with the motherboard.
Ensure the processor is installed properly.
Ensure the fan heatsink (cooler) is installed properly.
Ensure DRAM is seated properly.
Other tips to consider:
  • Try to use another working processor if you have. For swap testing scenarios and recommendations, you can visit How to Troubleshoot an Issue by Swapping between Processors.
  • Check for visibly bent or broken pins on the motherboard. Physical damage may affect optimum functionality of the processor.
  • Check if the front panel header connector is firmly plugged into the board.
  • Check cable connections for monitor, power supply, and fans.
  • Check the monitor for video input selection: VGA, DVI, HDMI, or USB-C.
Jose B.
Sebastian6
Bonjour,
La carte mere est une GIGABYTE B760M GAMING X AX DDR4.
Les 2 barrettes RAM sont des CORSAIR VENGEANCE LPX SERIES LOW PROFILE 16 GO (2×8 GO) DDR4 3200 MHZ CL16.
Elles sont placés des les slotes A2 et B2.
Jose_Intel
Hello Sebastian6
Thank you for reply.
Could you please confirm if the steps were followed?
Jose B.
Sebastian6
Bonjour,
Il n'y a qu'un seul socket PCIE sur la carte mere.
La DRAM est compatible avec la carte mere.
Elle est correctement installée.
Le processeur et la pate thermique sont correctement installés.
Je n'ai pas d'autre processeur pour tester.
Merci pour ces reponses.
Jose_Intel
Hello Sebastian6
Thank you for the confirmation.
We are sorry to hear that after the troubleshooting, the issue persisted. This time we would like to recommend you process the RMA with us, after verifying that your warranty is still active here, directly contact Intel Customer Support to initiate the RMA process (you cannot do this through the forums). Here are the pages where you can look up contact information, including local/country phone numbers, by geography:
U.S. and Canada: Intel Customer Support
Europe, Middle East, and Africa: Intel Customer Support EMEA
Asia-Pacific: Intel Customer Support APAC
Latin America: Intel Customer Support LAR
I will send some information privately. Please keep in mind that this thread will no longer be monitored by Intel. Thank you for your understanding.
Jose B.
