17147 Discussions
Difference PCIe 3.0 compatibility/performance betwen Xeon E5-26xx V1, V2, V3 and V4 ?
I will like to build 2 server with 2 Xeon and 4 graphic cards with SLI mode.
A first server will be with Dual Xeon E5-2687W V1 and ASUS Z9PE-D8 WS, the second with Dual Xeon E5-2697 V3 and SuperMicro X10DRG-Q.
For do it, i need 2 motherboard accepting true 4 way SLI x16PCIe.
-From ASUS Z9PE-D8 WS :
https://www.asus.com/Motherboards/Z9...lpDesk_Manual/
PDF file at # 225 " A.1 Z9PE-D8 WS lock diagram " :
http://dlcdnet.asus.com/pub/ASUS/mb/...910.1496734718-
-From SuperMicro X10DRG-Q :
http://www.supermicro.com/products/m...0/x10drg-q.cfm
PDF file at # 18 " System Block Diagram ":
http://www.supermicro.com/manuals/mo...2/MNL-1677.pdf
On Asus there are this information " Full PCIe 3.0 performance requires a 22nm CPU " :
https://www.asus.com/support/faq/1002943/
Xeon E5-2687w V1 are 32nm.
Asus council to contact Intel for to Know if our CPU can create or not " Full PCIe 3.0 performance ".
I dont't find any information in Datasheet or other about this subjet with Xeon E5 26xx, V1 and V2 and V3 and V4.
I will like to know if Xeon E5-2687W V1 and Xeon E5-2697 V3 can benefit at the maximum of " Full PCIe 3.0 performance "?
I will like to know if there are a diffence of performance/benefit betwen Xeon E5 V1 and V2 and V3 and V4 about PCIe 3.0 SLI performance ?
And next V5?
Where i can find this information and to recognize this information in Intel documents Xeon E5 ?
Best regards
Xavier
Hello XavierFR,
Thank you for contacting Intel Communities.
Thank you for bringing this to my attention.
Since the PCI Express 3.0 is a standard, it means that there isn't any difference in compatibility/performance on the processors that support it, the Intel® Xeon® Processor E5-2687W will perform the same as the Intel® Xeon® Processor E5-2697 v3.
To know if a processor supports PCIe 3.0 you can check the following link:
http://ark.intel.com/ ark.intel.com > Processors > Intel® Xeon® Processors > Choose the Family > Choose the Processor > Expansion Options > PCI Express Revision.
As for the SLI support, it depends on the motherboard and the graphics cards being used.
I hope this information helps.
Juan V.
Hello XavierFR,
Juan V.
