16580 Discussions
Does a T7300 with stepping "B0" work well?
Recently, I get a es sample of T7300 (2.00GHz, 800MHz FSB, 4M L2 cache) .
I checked it by tool "cpuz", so I get its information: stepping: 4, revison: B0, specification: "Genuine Intel(R) CPU @2.00GHz(ES)".
I have used it for some days, and i find that it generates a great heat.
I run it with a stress tool, when it gets a 60% loading, it gets 70°C, and when it gets a 100% loading, it gets 84°C. Its idle temperature is 51°C.
Does the temperature properly?
And i see that the T7300 also has B1, B2 steppings, what the detail upgrades from B0 stepping?
Thanks very much!
the temps seem a bit high, but then you are using an engineering sample, so there is no much to say. Get a proper retails or OEM CPU and then see.
BTW are you and end user or a company? because end users arent supposed to have ES chips
oh well good luck with that one then!
Well, thanks, but I find I cannot bear the high temps.
I sent it to a friend of mine.
