17147 Discussions
Does the i5-2405S have Intel Smart Cache?
Adolfo_S_Intel2
This processor supports what is call Last Level Cache (LLC), you can check the following specifications:
&# 159; Last Level Cache
– Logically shared across all cores
– Physically divided into slices
Bi-directional ring
– Links cores and cache slices
– Routes cache requests to the right slice
Cache address assignment algorithm reduces bottleneck potential in any one slice
&# 159; Ring architecture and multiple LLC entry points increase core to cache bandwidth up to 4x*
I'm building a HTPC and I'm not sure what processor to select; i5-2405S or i3-2125. What will get the best performance? 6 MB/LLC vs 3 MB/Smart Cache?
Both have HD Graphics 3000 at the same speed.
I also realize the 2405S has two more cores, but in the HTPC I don't expect this to make a big difference in HTPC. They both have the same clock speed.
Appreciate answers as I'm out of my area of competense.
Rolf
Adolfo_S_Intel2
I would suggest checking the following comparison chart:
http://ark.intel.com/compare/59080,55446 http://ark.intel.com/compare/59080,55446
I personally do not see many differences between both processors, if you believe that you will not need 4 physical cores, and you want to save some money, you might want to think about the i3-2125, but the final decision can be taken only by you.
If you are still not sure about what processor to purchase, I would suggest contacting any of our Authorized Intel® Distributors, so they can provide you further recommendations.
