17154 Discussions
Force P-core and i9-13900K
Nehu
Hello.
I have a 13th Gen Intel© Core™ i9-13900KFand it is updated to its latest embedded microcontroller version (along with the bios).
I was wondering if Forcing it to use p-cores would be bad for the CPU (im thinking off the whole melting 13-14 gen cpu thing, which was why the patching  of the Microcontroller was needed)?
Earl_Intel
Hi Nehu,
For us to better assist you and determine the most appropriate resolution, could you please provide the needed details listed below:
  • Can you clarify us what you meant by "Forcing it to use P-Cores"? do you mean it by disabling the E-Cores and only use P-Cores while using the PC?
  • What is the exact make and model of your motherboard?
Once we have this information, we will be able to proceed with the next course of action and work towards resolving the issue you are facing. Your cooperation is invaluable in helping us provide you with the best possible support.
Earl E.
Earl_Intel
Hi Nehu,
Earl E.
Earl_Intel
Hi Nehu,
Earl E.
