17066 Discussions
HELP!!!! High temperature i7-4790k with GT H110i!!!
NHsie3
Hi everyone!!
I need some help here. My computer is having the temperature of 35-39C for idle. To be honest, since I am using a good water cooler, I was expecting that the temperature of my CPU to be around <25C (room temperature). </span> When I try to change my clockspeed to 4.5GHz, the cpu starting to throttling and I am not sure what was the cause of this. It would be great if u guys could tell/suggest me the best solution for solving this thing. If u guys need more information, I would be delighted to provide but u might have to explain it in detailed because I'm just an amateur in computers
Current Situation:
https://www.dropbox.com/s/sddtqfcwiwbsnoo/Screenshot%202016-04-02%2000.00.17.png?dl=0 https://www.dropbox.com/s/sddtqfcwiwbsnoo/Screenshot%20...
Extra information
https://www.dropbox.com/s/vba20q4evd3qq85/Screenshot%202016-04-02%2000.22.16.png?dl=0 https://www.dropbox.com/s/vba20q4evd3qq85/Screenshot%20...
Stress test using Intel ETU
https://www.dropbox.com/s/wsgeedq4dyfszhs/Screenshot%202016-04-02%2000.00.50.png?dl=0 https://www.dropbox.com/s/wsgeedq4dyfszhs/Screenshot%20...
My Computer Specs
CPU: i7-4790k
Motherboard: Asus Maximus VII ranger
GPU: GTX 980
CPU cooler: GT H110i water cooling
RAM: 16GB 1600mhz
Power supply: Centauro XTK-CB-1000M 80plus bronze 1000w
Case: Corsair Graphite Series 960t
What I tried before:
  • Checked the thermal paste was installed correctly
  • All the components are installed correctly
  • Updated the newest BIOs
  • Changed the settings according to this but I want to have the clock speed around 4.5-4.6GHz
My goals:
Ideal CPU idle temperature: <25C</span>
Ideal clock speed: 4.5-4.6 GHz
Ideal stress test temperature: <75C</span>
Hi NobleHsieh,
The base frequency of the i7-4790K is 4.0GHz and with Turbo Boost is 4.4GHz. The maximum speed will be reached by only one of the Cores, the rest will run slower. If you over clock all the Cores; processor temperature is going to be hooter than usual.
The chart below shows the maximum speed per Cores using default settings.
http://www.intel.com/content/www/us/en/support/processors/000005523.html http://www.intel.com/content/www/us/en/support/processors/000005523.html
Miguel
Hi NobleHsieh,
Miguel
