16620 Discussions
Help!How to get ECC error log of Xeon Ice Lake ?
Admin123
    I used Ice Lake processor(Intel® Xeon® Gold 6330) and GIGABYTE board to test DDR4 RDIMM.
    I used IMCi_CHi_MCi_STATUS.vaild to check whethere there is an ecc error, and it is useful to locate right sock, ctrl and channel. Then I used retry_rd_err_log to decode DQ\ROW\COL, but retry_rd_err_log.vaild is always zero which means I can't decode more info.
    I suceeded in decoding ECC errors for Skylake-SP (also Intel® Xeon® Scalable Processor) by same way.  But it is invaild for Ice Lake, is there somthing I missed?
    Btw, I set ERROR_CONTROL.bit1 for Skylake-SP to enable mode-1, but bit1 is readonly for Ice Lake. So I did nothing with ERROR_CONTROL register.
IntelSupport
Community Manager
Hello Admin123,
Thank you for posting your question on this Intel Community.
To better assist you, please provide us with the following details:
  • GIGABYTE board model
  • DDR4 RDIMM part number
  • Please let us know why you need this information.
Wanner G.
Admin123
  • GIGABYTE MR92-FS0
  • Our company's RDIMMs, so the part number is secret
  • To develop program  for  testing D4 RDIMM
IntelSupport
Community Manager
Hello Admin123,
Thank you for your response.
I will look into your request, and provide an update soon.
Wanner G.
IntelSupport
Community Manager
Hello Admin123,
Based on the information provided on this thread, we recommend that you contact your Original Equipment Manufacturer (OEM), Gigabyte, for further assistance. If Gigabyte suspects a processor issue, they have a path to escalate to Intel engineering for debugging.
I hope you find this information helpful. We will proceed to close this thread.
Wanner G.
Admin123
Hi IntelSupport,
Thanks for your reply.
Is it possible that there are some registers i haven't enabled , and it caused errors can't be logged to registers "retry_rd" ?
Or ICE LAKE needs new registers to decode ECC error info,  instand of registers "retry_rd" which are used by SKYLAKE-SP?
Best Regards
IntelSupport
Community Manager
Hello Admin123,
We recommend that you follow the suggestions we shared on our previous post.
Wanner G.
