High CPU usage
Kragier
I have a problem with the Core i7-7700 processor in the task manager shows me the high load capacity of the processor, I do not know how to deal with it. I scanned the entire disk with antivirus for viruses, bitcoin miners and found nothing. He has such a problem as soon as I start the computer. Therefore, the load capacity should be kept at a low level.
JosueO_Intel
Hello Kragier,
Thank you for posting on the Intel communities. In order to have a better understanding of the issue, please share with us the following information:
  1. Model of motherboard and RAM
  2. Did you overclock the processor?
  3. Did you enable Intel® XMP? If so, which frequency were you using?
  4. When did the issue start happening?
  5. Have you gotten any error codes or BSODs?
  6. Screenshot of task manager under the performance tab.
Also, please download and install the Intel System Support Utility (Intel SSU):
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View".
Click on "Next", save the report and attach it to your response.
Josue O.
Kragier
Hello Josue O
- My motherboard is B150M PRO-VDH, Ballistix Ballistix Sport RAM, DDR3, 8 GB, 1600MHz, CL9
- I did not turn on Intel® XMP
I formatted the disks and uploaded windows from scratch, so far I have improved, maybe it is deceptive but at the moment it looks like everything is fine
JosueO_Intel
Hello Kraiger,
Thank you for the information provided, I am glad to hear that after reinstalling Windows* the issue seems to be solved. I will be following up on Friday just to check if everything is working fine.
Josue O.
Kragier
Also thank you for your time and willingness to help.
JosueO_Intel
Hello Kraiger,
I was following up to check if the issue has returned or if it has been working without any issues.
Josue O.
JosueO_Intel
Hello Kraiger,
Josue O.
