16916 Discussions
Higher Speed RAM on Pentium Silver N5000.??
heyrobbie
hello...i am wondering if i can put a 8 Gb 2666mhz or 3200mt/s Ram on an Intel Pentium Silver N5000.....which has 4Gb 2400mhz on it expandable upto 8......can higher speed ram be put in it.??
Sebastian_M_Intel
Hello heyrobbie,
Thank you for posting on the Intel® communities.
Please visit the product specifications site: https://ark.intel.com/content/www/us/en/ark/products/128990/intel-pentium-silver-n5000-processor-4m-cache-up-to-2-70-ghz.html
Under Memory Specifications, you will see it goes up to 2400 MT/s. Also, as this is a Mobile processor, it should be installed in a laptop (most likely), so you will need to check with the system manufacturer (OEM) for the RAM compatibility.
Sebastian M
Intel Customer Support Technician
Sebastian_M_Intel
Hello heyrobbie,
Sebastian M
heyrobbie
Yes...its an ASUS laptop X507MA....i suppose then it supports RAM speeds upto 2400 MT/s only....not above.
Sebastian_M_Intel
Hello heyrobbie,
Thanks for your reply.
The CPU is limited to go up to 2400 MT/s, but that also depends on the laptop. You may want to double-check with Asus* for this.
We will proceed to close this inquiry, if you have any additional question; please submit a new thread as this post will no longer be monitored.
Sebastian M
faduck
I installed DDR4-3200 and it works fine but it runs at 2400Mhz.
2666Mhz should be fine.
ProDigit
Old question but here's my response from 4 years in the future:
If 2400Mt ram modules are hard to find, you can install faster ram.
It will still run at 2400MT/s just fine.
There is only one benefit of running higher speed modules, and that's CAS latency.
Overall CAS latency reduction accounts for less than 1% of speed improvement at the same frequency, so you won't necessarily see a speedup boost.
However, if modules are priced in the same price category (2400 vs faster memory), go for the faster memory.
If the price difference between modules is more than $5-10, then you're better off going for more memory.
