First of all, I know this is not the right forum to mention this but I tried to find the RDC (Resource Documentation Center) forum but I could not find it. If I need to send this information to another forum please let me know.
I know it is a small error but for the purposes of completeness I would like to know if it could be fixed. The error can be found in both the systems programming guide (the combination of 3A, 3B, 3C, and 3D) and in 3A specifically -- I have not checked the compilation of all volumes but maybe it can be found there as well. The error is in Figure 9-2. 32-Bit Task-State Segment (TSS).
If you look at the table between 88-byte offset and 96-byte offset you find 98-byte offset instead 92-byte offset which is what should be in that place.
Even though it is minor, I almost fell for it while I was copying each register segment offset and so may someone else (or perhaps not but I do think it should be fixed for the sake of completeness).
Thanks beforehand.
Hello The_Coding_Knight,
Thank you for reaching out to the Intel Community Forum
I will do further review on this matter and post the response on this thread once it is available.
Brenz L.
Thank you for joining the Community. Your question is related to our Intel® Partner Programs, so we will transfer your case to our Programs Support Team. They will contact you via email as soon as possible.
We will now proceed to close this thread. Please keep in mind that it will no longer be monitored by Intel.
Brenz L.
