In bios I enable intel VMD, and create a raid0 disk, with 2 990pro ssd.
but as I install windows11, and load driver, either the driver under vmd forlder or raid folder does not work, after loaded, no disk show up.
and after I turn VMD to disabled, I can install windows 11 to one of my ssd, after installation is done, I run RSTSetup.exe, it said unsupported platform. At the page which I download this exe file, it said this exe support 11~13 gen. intel CPU.
I need some help to setup raid0 on my 14700hx laptop.
- Tags:
- 14th Gen. raid
Did you try and successfully install windows11 with a raid0 disk on a 14700hx platform?
The approach you mentioned, I all tired, but nothing works.
The intel's download page, shows the latest version of RSTSetup.exe is 18.7.6.1010, when I run it on my 11th gen pc, it also shows this version number.
And when I enter my 14700hx laptop bios, in the raid settings, it shows intel(R) RST 19.5.5.5727 RST VMD Driver, where can I find this version of RSTSetup.exe ?
my stupid.
I extract the driver from the old version of RSTSetup.exe, so when I install windows, I can't load the correct driver.
Now, I extract the driver again from version 20.x. and raid 0 works.
my stupid.
