Not so fast on the refund.
Run the IPDT
https://www.intel.com/content/www/us/en/support/articles/000005567/processors.html
Post the results. Then, So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[If it weren’t for C, we’d all be programming in BASI and OBOL.]
Here it is, i booted on safe mode with internet, just so you know, these are the bsods i been getting:
KMODE_EXCEPTION_NOT_HANDLED
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
SYTEM_SERVICE_EXCEPTION
And down here is the report:
Please run the iPDT as well. It should work in Safe Mode.
