17151 Discussions
I5 10500H Overheating problem?
I510500
My Gaming Laptop MSI GF65 10UE Thin's CPU started Overheating after 2 years and losing performence right now it's 94 degrees celcius and I am not playing any games just doing casual things like using discord and my web browser. I already tried re-pasting the cpu + gpu but it didn't change ANYTHING I hope someone can help me out if you have or know a solution please reach me.
pressed_for_time
Valued Contributor II
I see from the screenshot that the CPU temperature is 92C. The notebook GPU RTX 3060 is 83C.
I510500
I was just playing cyberpunk than the cpu and the gpu temperature reached to 100 degrees and my laptop crashed when I touch the laptop its literally melting its starting to make me angry.
pressed_for_time
As both the CPU and GPU are running at high temperatures is it possible to improve them by selecting a lower performance level when playing games and/or lower game settings. I know MSI had something called Cooler Boost on their laptops, is yours one of them. If so does selecting Cooler Boost make any difference.
It might be worth contacting the support department for your laptop at MSI and see if there is any help or advice they can give you.
