Cuando juego juegos de última generación con gráficos algo leves la temperatura de mi CPU se mantiene a 90°C y se usa en promedio un 20%
Mi GPU se usa un 50% y no pasa de los 50°C
Mi duda es ¿Es normal que mi CPU se quede en esa temperatura de 2 a 4 horas promedio de juego seguido?
Hello Akzhura,
Tenga en cuenta que he utilizado una herramienta de traducción web para traducir esta respuesta, por lo tanto, puede haber alguna traducción inexacta.
Thank you for reaching out. I understand that your processor is reaching 90°C, it is high but not immediately dangerous as the CPU can handle up to 100°C before the thermal throttling is enabled.
Please answer the following questions:
When did the issue start? Was it after any recent system updates?
What are the games you have played?
What is the Cooling Setup for your CPU?
Have you double checked that the game is using your Discrete Graphics Card and not the Integrated Graphics?
Please generate an SSU report to help me further analyze important details on your system. To generate the SSU report, please refer to the article: How to get the Intel® System Support Utility Logs on Windows*. Please send us the generated SSU.txt file.
I look forward to your response!
Robbie R.
Hello Akzhura,
Robbie R.
Hello Akzhura,
Robbie R.
