17158 Discussions
I7-4790k temps spiking into the temp range of 82-87C with the included heatsink while cpu usage shows less than 50% usage. I am not running any cpu intensive tasks. is this normal behavior?
CYild
the rest of the time the cpu idles at a reasonable 60ish C
CYild
Update: I ran the intel processor diagnostic tool and it fails every time I run it with these results, even in safe mode:
--- IPDT64 - Revision: 3.0.0.23.W.MP
--- IPDT64 - Start Time: 2/20/2016 1:33:03 PM
Processor 1
Genuine Intel CPU Test
Module Version: 1.0.12.64b.W
Start Time: Sat Feb 20 13:33:03 2016
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
End Time: Sat Feb 20 13:33:03 2016
Total Time: seconds: 0
Temperature Test
Test Result - FAIL
Expected: Greater than 1 degrees below max
Received: 0 degrees below max
End Time: Sat Feb 20 13:33:04 2016
Total Time: seconds: 1
--- IPDT64 - Temperature Monitor Results
Temperature Monitor will begin when CPULoad Test starts
Temperature Monitor Stopped
System Information
Processor Name: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
Processor Information: Intel64 Family 6 Model 60 Stepping 3
Number of Physical Cores: 4
Number of Logical Cores: 8
Installed System Memory: 16 GB
Operating System: Microsoft Windows 10 Pro 64-bit
Graphics Information: NVIDIA GeForce GTX 980 Ti
System Product: Z97-PRO(WI-FI AC)
System BIOS: 2205
System Serial Number: System Serial Number
--- IPDT64 - End Time: 2/20/2016 1:33:04 PM
--- IPDT64 - Result: Pass
FAIL
Allan_J_Intel1
This issue has been already reported here:
Please take a look at the link above because you will need to adjust some BIOS settings in order to address this problem.
Allan.
CYild
I will update my bios and post a screenshot from XTU with my setting, but It looks like they are at the recommended settings. I looked in the forum you posted and found that most of them had higher values than i have. I have a z97-Pro Wifi AC
CYild
here are my current results prior to updating bios because im not at home, just remoting into the system. idle: aprox 65c load aprox 90c
CYild
I have updated my BIOS to the latest version an this is the result of the new test
