17061 Discussions
I7 5930k Package question
CGanz
Hi, i received my new processor a day ago, but something really disturb me, the cpu inside the Plastic Blister was Slightly turned so the blister was not properly closed.
When i opened the internal cardboard tray, the blister just opened by himself like a spring, but hopefully the cpu did not move or fall.
The factory seal was intact and properly closed, the cpu appears not used, with just a square mark on the ihs, so i assume it's normal factory testing.
The fpo code is ok on the ihs and on the sticker, with 3 years warranty recognized by the site.
Now
is safe to use this processor?
Is it a normal factory packaging error but acceptable for intel quality standards?
or
is it better to RMA without even try it?
I know that my concern can be a little exagerate, but even if it's not my first custom build, it's the first time i see a new processor boxed in this manner, and before use it with other brand new components, i want to be sure that this can be acceptable.
Thanks, and sorry for my pretty basic english.
Hello, Deathblow85:
In this case, I would recommend contacting our phone support at http://www.intel.com/content/www/us/en/support/contact-support.html Contact Support in order to help you with this.
Amy.
Hello, Deathblow85:
Were you able to contact the phone support? Did they help you?
Let me know your findings.
Amy.
CGanz
Thanks Amy
The guy at the phone support was very professional.
My "issue" is solved and the system is now running silky and smooth.
Deathblow85, that is really good to hear! Hope you enjoy your processor.
If you need further assistance let us know.
Amy.
