I7 - 8550
I have juts bought a laptop ASUS with a i7 8th - 8550 , I just wonder the normal temperature for this processor, considering that is new and i am just surfing on internet.
I am asking this as i feel warming on keyboard, but i wanted to compare with standars or normal temperature for this item. I used a program to measure temperature and from the start (after turn on) the temp is around 43C.
I add the image of temperature when only internet is on , and on stress.
P.D. Ambient temperature is around 27C .
Thanks for all. I will return the laptop is temperature is anormal
n_scott_pearson
These temperatures are perfectly normal and expected. Your laptop's cooling is working as designed.
Hope this helps,
Thanks a lot... I was worried because I will use this laptop for 3d designe and just right now with the laptop charging and just surfing on internet the temperature is 47C , and the laptop is new!!
Also the laptop is ultrathin so I understand that the keyboard is a little hot.
