16594 Discussions
I9 13900k thermal throttle
Themilosz
I build a new pc it’s i9 13900k my aio is custom loop xt305i when I stress test it it thermal throttles n under heavy load n I get a problem the red led shines on the motherboard could any one help the xt305i had pre applied thermal paste can’t change volts in bio
DeividA_Intel
Hello Themilosz,
Thank you for posting on the Intel® communities. I understand you are having an issue with your new setup due to the thermal throttling, I will happily assist you on this matter.
To have a better view of this problem, I would require you to confirm this:
1. What is the brand and model name of the xt305i?
2. Did you overclock your processor?
3. Are you using the Intel® Extreme Tuning Utility (Intel® XTU)?
4. What is the LED that gets triggered (CPU, GPU, other)?
5. Are you getting an error or a blue screen of death?
6. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
Deivid A.
DeividA_Intel
Hello Themilosz,
I am getting back to you because I want to know if you had the time to read my previous post and collect the information requested. If you need further support, just let me know.
Deivid A.
DeividA_Intel
Hello Themilosz,
I was checking your thread and noticed that I have not heard back from you. I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
