17158 Discussions
IRQL_NOT_LESS_OR_EQUAL error after Windows 10 Update - Intel - System - 10/27/2016 12:00:00 AM - 1.0.0.1030 - How to fix?
BWint6
Hi there,
I recently got a Windows 10 update appear - "Intel - System - 10/27/2016 12:00:00 AM - 1.0.0.1030"
I did some googling and found a way to stop the update from happening via the Windows 10 hide update tool.
Or so I thought - it turns out that Windows 10 installed this update in the background - leaving me no choice but to have it installed.
http://imgur.com/OEoeog2
I tried to uninstall it, but it doesn't appear in the list where I can uninstall it.
Anyway - after the update was automatically installed, it installed Intel Turbo Boost and began to run this in the background.
I noticed a temp spike after this so I clicked to disable it, in the program. I then clicked back to 'enable' it - and suddenly my system went into a BSOD and displayed the error IRQL_NOT_LESS_OR_EQUAL
After the restart I left Turboboost enabled and my system has been fine for the last week. However, when I was in the middle of working on a file - My system froze and I got this same issue IRQL_NOT_LESS_OR_EQUAL
I checked event logger and found this -
"The computer has rebooted from a bugcheck. The bugcheck was: 0x0000000a (0xffffc785cb0cb0c0, 0x0000000000000002, 0x0000000000000001, 0xfffff803b40a4fa9). A dump was saved in: C:\WINDOWS\MEMORY.DMP. Report Id: 3fd11b10-aa78-4871-b851-6e3045c1967d."
I didn't have any issues before this Windows 10 update but I am not sure if the issue is related to Turbo Boost - as this app also got installed by the Windows update.
I am running a
ProcessorIntel(R) Core(TM) i7-6800K CPU @ 3.40GHz, 3401 Mhz, 6 Core(s), 12 Logical Processor(s)
Is this Windows 10 update (Intel - System - 10/27/2016 12:00:00 AM - 1.0.0.1030) an issue and does anyone know how to uninstall it?
Or does anyone know of a fix for this BSOD - IRQL_NOT_LESS_OR_EQUAL
Thanks for your time and help
Hello bryce_w,
According to your description, the issue seems to be pointing to the Windows® 10 update. I just want to know; is this the Turbo Boost app you are referring to; https://downloadcenter.intel.com/download/26103/Intel-Turbo-Boost-Max-Technology-3-0 Download Intel® Turbo Boost Max Technology 3.0?
To uninstall the update, try using the System Restore option. Find it here; https://www.howtogeek.com/206271/how-to-roll-back-or-uninstall-a-problematic-windows-update/ How to Roll Back or Uninstall a Problematic Windows Update, last option.
I believe this update is the November Update, have you tried with the Creators Update?
The content on the above site is not controlled by Intel. This information is offered for your convenience and should not be viewed as an endorsement by Intel for the merchants or services offered there.
Amy.
BWint6
Hi Amy,
Yes it is the Intel Turbo Boost Max Technology 3 application
I tried to use system restore but the restore point doesn't appear
http://i.imgur.com/kxOouB7.png
Suggestions?
/thread/113491 bryce_w, my apologies because in order to use this option you must have created a restore point. But you can try the "Start up Repair" or the "Refresh this PC"option, use this steps; https://support.microsoft.com/en-us/help/12415/windows-10-recovery-options https://support.microsoft.com/en-us/help/12415/windows-10-recovery-options
One more thing I would like to mention is that Intel® Turbo Boost Max Technology 3.0 app can only be downloaded from the site I mentioned before, the Windows update does not include this app within the update.
Amy.
BWint6
You can clearly see from my screenshot that no restore point was created on my computer when this update was installed.
Also, the windows update downloaded and installed the Turboboost app, because it wasn't on my computer before.
Are you suggesting I have to reset my entire computer?
The app should not have been installed within the update, the app has to be manually downloaded from; https://downloadcenter.intel.com/download/26103/Intel-Turbo-Boost-Max-Technology-3-0 Download Intel® Turbo Boost Max Technology 3.0.
Did you try the "Start up Repair"? If it does not work the "Refresh this PC" is just a suggestion.
Amy.
bryce_w, I just wanted to check if you were able to follow the suggestion mentioned before.
Amy.
BWint6
No it did not and now I am getting daily crashes.
Here is the latest crash report
On Tue 8/1/2017 21:56:04 your computer crashed
crash dump file: C:\WINDOWS\memory.dmp
This was probably caused by the following module: http://www.google.com/search?q=intelnit.sys intelnit.sys (IntelNit+0x6612)
Bugcheck code: 0xA (0xFFFFA909152E5800, 0x2, 0x1, 0xFFFFF8025804E87A)
Error: http://www.google.com/search?q=MSDN+bugcheck+IRQL_NOT_LESS_OR_EQUAL IRQL_NOT_LESS_OR_EQUAL
file path: C:\WINDOWS\system32\drivers\intelnit.sys
product: http://www.google.com/search?q=Intel(R)%20Turbo%20Boost%20Max%20Technology%203.0%20Driver Intel(R) Turbo Boost Max Technology 3.0 Driver
company: http://www.google.com/search?q=Intel%20Corporation Intel Corporation
description: Intel(R) Turbo Boost Max Technology 3.0 Driver
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: intelnit.sys (Intel(R) Turbo Boost Max Technology 3.0 Driver, Intel Corporation).
Google query: http://www.google.com/search?q=intelnit.sys+Intel%20Corporation+IRQL_NOT_LESS_OR_EQUAL Intel Corporation IRQL_NOT_LESS_OR_EQUAL
bryce_w, I am sorry to hear that!
Let's try to uninstall the Intel® Turbo Boost Max Technology 3.0 app, follow the steps below for this:
  1. Open the Add/Remove Programs window.
  2. Find the Intel® Turbo Boost Max Technology 3.0 app.
  3. Right click Intel® Turbo Boost Max Technology 3.0 app and select Uninstall.
  4. Follow the prompts stated by the Intel Installation Framework window to complete the process.
  5. Reboot the computer after the uninstall process has finished.
In the meantime please let mean know your motherboard model.
Amy C.
bryce_w, if you need further assistance let us know.
Amy C.
