17079 Discussions
Icelake-D HCC - SATA TX compliance pattern generator
Pavel_qio
Is there a tool or generate SATA TX patterns to conduct the compliance measurements with Intel Icelake-D HCC SoC?
Intel PLEVT is not supported, Intel IO Margin Tool does not support On-Target configuration...
Thank you.
Best regards
Pavel
DeancR_Intel
Hi Pavel_qio,
Thank you for posting in the Community!
Please share more details about the issue so I can assist you effectively.
Can you describe the issue more to us?
What is the exact model of your processor?
Dean R.
Pavel_qio
Hello Dean R.
I need to perform SATA TX measurements on the HSIO pairs configured to SATA ports. In the Intel documentation I have found that this can be done using Intel IO Margin Tool. There are two possibilities to run this tool: Host Mode or On Target Mode. For the Host Mode XDP is needed (which I don't have) and On Target Mode is not supported. This is valid for Windows version. Linux version supports just Margin test (so, not the Signal Quality & Compliance option). Other tools which Intel used in the past like PLEVT, PhyTune are not supported. Target processor is Intel Xeon D-2700.
Best regards
Pavel
DeancR_Intel
Hi Pavel_qio,
This is an acknowledgement message for your inquiry, do please wait as this will be investigated internally to be able to provide a resolution to your request. I will get back to you once I have the necessary information.
Dean R.
Azeem_Intel
Hi Pavel_qio,
Thank you for reaching Intel Communities.
The Intel® Xeon® Processor D-2700 HCC is classified as an embedded processor, which falls outside the scope of our current support. We kindly request that you submit your query in the forums dedicated to Embedded Products, where a representative from the specialized team will assist you.
If you have any additional questions or concerns, feel free to let us know.
You can access the forum here: https://community.intel.com/t5/Embedded-Products/ct-p/embedded-products
Azeem
Intel.com/vroc
