17150 Discussions
Insane Fortnite stutters on ASUS zenbook 13
Fatness
Need help with running Fortnite on ASUS Zenbook 13
I have tried so many different things but for aome reason the game just won’t stop stuttering, even on low settings and lowest res possible (1280x720) in performance mode. I can get up to 120FPS sometimes but the stutters wont go away.
Things i have tried so far:
I tried to prioritize fortnite as high/real time using process lasso.
I tweaked windows with the power plan, set the minimum processor state to 100, changed power plan to high and many more additional things such as turning off background apps etc.
I tried to optimize the gaming experience using VTRL optimizer
Checked my cpu temp using coretemp (all around 70 degrees celsius)
The stutters won’t get fixed and the cpu utilization hardly ever goes above 60%, GPU usage is 20-25% most of the time.
As far as my knowledge goes, fortnite chapter 6 is a CPU heavy game and needs a strong processing power. But I just can’t understand why the stutters won’t get fixed even if i prioritize only fortnite using process lasso.
I have also done a clean reinstall of the windows, debloated the laptop snd many more things such as updating all the drivers etc. regardless of all the tweaks, the game just wont run smoothly.
Laptop specs:
11th gen intel i7-1165G7 @2.8GHz 16GB RAM Intel IrisXe Graphics (Integrated GPU Windows 11
Any suggestions and help is appreciated
ArchieD_Intel
Hi Fatness,
Thank you for reaching out to the Intel Community Forum regarding the stuttering issue you've encountered with Fortnite. To assist us in investigating the issue, please provide the following details:
  1. Have you tried using the OEM driver for testing?
  2. Have you used DDU to completely remove all residual drivers and installed a new one?
  3. Have you tried adjusting the graphics settings?
  4. Did you verify the game files or reinstall the game?
  5. Could you provide a screenshot of your in-game display and graphics settings?
  6. Which gaming platform did you use to download the game?
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
Archie D.
ArchieD_Intel
Hi Fatness,
Did you have a chance to review the previous post? Please feel free to reach out if you have any questions. Thank you.
Archie D.
ArchieD_Intel
Hi Fatness,
Archie D.
